Spec 3+
joedls
Dragracer wannabe
Lake Forest, CA
I just got a Spec 3+ clutch for my car. It did not come with a shim for the TOB. I called Spec and they told me it is not required. All my research here says I need it if I'm going to use my stock flywheel. Is the guy I spoke to full of shit? Is there any way for me to verify this? Any help is appreciated.
94tbird
4R70W FTMFW
stock flywheel shim is needed unless they redesigned it. spec flywheel, no shim
joedls
Dragracer wannabe
Lake Forest, CA
See, that's what I thought from all that I've read. I told the guy that. He said it isn't required. I asked him if it had been redesigned and he said he didn't think so.
ArtQ
Alpha, NJ
I bet I could tell you word for word what they will say after install.........
Must be someone there that knows the answer?
07 procharger
Addicted to modding
Red Deer Alberta
yup, really weird ones...clutch engauges at the top of the pedal ...like a inch from the top...also disengauges about 3 inches into the pedal.
joedls
Dragracer wannabe
Lake Forest, CA
I just spoke to someone named Jeremy at Spec. He told me that the only time they send out a shim is with the stock clutch and their flywheel. He reiterated that I don't need it with their clutch and a stock flywheel.
I'll find out when I install the clutch, I guess.
Ken04
gm troll basher
Santa Rosa Ca.
from experience, I would send Jeremy an e-mail. Ask him to respond to you the instructions he gave you re; the shim. You'll have a hard copy and a time/date. Just in case.
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
Yep written record is hard to argue with man , I have the same thing saved for many things all the way down to insurance coverage for added parts .
Rypper1
Prairieville, LA
+1 Because when it doesn't work properly they are going to drag on the BS then tell you it is out of warranty and you are out of luck. Been there, done that. Won't ever put Spec in my car again. Although I have to admit that the 3+ is the only clutch from Spec that I have heard good reports on for the S197 platform.
shawn13
Dwight,Illinois
I put in the 3+ with the alum.presure plate and the fidenza alum. flywheel with no shims . Everything works great but I will tell you this clutch is damn grabby for the first 1000 miles.
Ohh and bleed the shit out of it
Kiddigretarzz
Reykjavik, Iceland
I´m running Spec Stage 1 clutch with a 8 bolt flywheel. Had my mechanic install it. Everything seemed to work fine with shifting the car till after a month when it just would not go out of gear. Had my mechanic take a look at it and he found out that there was a SHIM needed for the clutch for it to be able to release. Thankfully my mechanic was able to make a shim to fit and it works "fine" now.
I´ve been thinking about the Stage 3+ but considering how awful the drivability of the Stage 1 is I´ve been a little hesitant.
Rypper1
Prairieville, LA
Dude, save yourself the trouble and get a Mcleod RST. It will feel/drive like stock and hold everything that Hellion can throw at it. Trust me, I found out the hard way. Yea, it cost more but it is WELL worth it.
Kiddigretarzz
Reykjavik, Iceland
Believe me I´ve been looking at the Mcleod´s, just anything else that will get my girlfriend to wan´t to drive the car again ... after all, she owns half of it :)
Rypper1
Prairieville, LA
Put the McLeod in it. She will be able to drive it again. My wife couldn't drive mine with the Spec 2+ in it, hell I really couldn't either because of all of the problems...long story there. Anyway after I had the McLeod put in she had a blast driving it. She really loved the Hellion kick, almost couldn't get her out of it.
