Young Punk Build Volume II
chad05gt
Lake Charles, La
Im shocked to shit to see you using all 4 bolts on the radio... :moon:
...even thought the excess of every bolt is dremmelled off... right!?
Do THAT on EVERY bolt on the car... any excess is just wasted wieght...
... happy grinding!!!
Matt D
S197 Pilot
Toronto,Canada
:roflmao::roflmao:
Matt D
S197 Pilot
Toronto,Canada
Well , I decided to finally install the SOS radio pannel. Using two autometer carbon fiber short sweep gauges :)
Here is a quick shot of the fittings where the oil sending unit hooks up, I split them with a T and an angle fitting so both oem oil and the autometer oil pressure gauge works
Wire harness for the new deck.. need to soider it up
Some of the wires I ran from both sending unit's and some grounds (not all wires in this pic)
Test fitting :p
Shortining the new harness for the deck and wiring up to the other harness that goes to the deck
Matt D
S197 Pilot
Toronto,Canada
All soidered up
In the white plug, there was another 10 wires that I took out because they are not needed for the new deck
Oh yea :) Im not a big stereo person but dam this deck makes the stock oem system sound amazing
dagamore
Poor Driver mod
K-town Germany
very nice, i would have used, and plan to, heat shrink, not el-tape, but other then that very clean setup.
any more photos of the oil sender splitter T thing? I guess thats the factory bung you are using right?
Matt D
S197 Pilot
Toronto,Canada
Wrapped the tape tight, all the wires were close If I slid the heat shrink over each one they might have shranked when the soider iron got close meh it's done right that's all that matters lol
Matt D
S197 Pilot
Toronto,Canada
Im using autometer brass fittings, I will have to get a closer shot with the sending unit installed aswell
