Axle Back Install Tips
NJ09GT
Northern NJ
Just got a set of GT500KR axlebacks for my 09 GT. Didn't install them yet, will soon. Any tips/advice on the installation? I appreciate any and all advice - and for the record this is my first install of axlebacks. Thanks again in advance!
Natural1
all around duguder
Angleton, TX
It is always nice to have someone around to tell you that the alignment is off and to re-adjust them one way or another, while you are under the car. You will need to remove (physically unbolt) the square hangers if you are not disconnecting the midpipes. It takes me around 20-30min on my back with no jack or jackstands. It is not a difficult job.
HOLYWD
S197 Junkie
x2
took me about 25 min .
2 people are a plus .
usafimj
Unbold axle back (1 bolt each) and if you'd like you can remove the entire setup including the black hangars (2 on each side with 1 bolt). Remove stock axle backs and reverse steps
TexasBlownV8
Formerly TexasBlownV6
Central Texas
I always just disconnect the mid-pipe and not remove the hangers at all. yes it does help having another person line up the the tips sticking out the bumper, both for location and depth.
For the muffler clamp, using a deep 15mm socket works best. Same socket works on the band clamp holding the mid pipe to your H or X.
irishpwr46
Official Site Vandal
NYC
make sure you have the clamps to install the new ones. the stock clamps are welded on
NJ09GT
Northern NJ
Thank you everyone
especially you irishpwr, not one person has advised me of this. Where can I get clamps to put these on? I appreciate the advice.
Bingo
Because street car
Phila, PA
Your new mufflers didn't come with clamps?
