2L8IWON
just stroke and bore your engine now and use 4v pistons and heads. would be cheaper
Is it that easy? What year heads would we need? And would there be all that much benefit to doing such a project? I am very interested in this idea
yes its that easy. 3.75" stroker and .20 bored and you got approximately 300ci. 5.0 is 302. Personally id jsut keep the 3v heads to ave on cost but you canbolt the terminator heads to the car as long as you use 4v pistons IIRC
I traded my 01 Cobra last fall for an 09 Bullitt because I wanted to build an S197. The only disappointment I've had is the looks of the 3V versus the 4V (I show more than race). First I started researching superchargers, then built shortblocks (might as well be 5.0L stroker if decide to go built) and if I understand you're saying I could use 4V heads if I use the correct pistons. Everywhere I've looked at modular shortblocks it says for 3V heads, 2V and 4V heads will not work. Where can I find info for such? What I really want is a supercharged 5.0L 4V.yes its that easy. 3.75" stroker and .20 bored and you got approximately 300ci. 5.0 is 302. Personally id jsut keep the 3v heads to ave on cost but you canbolt the terminator heads to the car as long as you use 4v pistons IIRC
Probably 8-10 gs...
