Upright compressor isolator/mounting pads - where to buy??
doogie
SE WI
I have a 60 gallon, 6HP upright compressor and have searched unsuccessfully in trying to locate some type of decent rubber/sound isolator pads to reduce the vibation/noise when it is running. I purposely designed one of my gaarges to have a small/insulated room for the compressor, but the vibration through the floor is annoying.
Any ideas on where I might find some rubber feet for this thing?? It would be nice to find something that has a mounting stud/bolt as I could attach it directly to the holes in the 3 legs.
Marc s
NASA AIX
Auburn, WA
I could not find them when I looked either. I used rubber conveyor belts cut into 24" pieces. And then bolted the compressor through them. It worked good and was free.
pieperz06
i need to get blown
Corpus Christi,TX
have you thought of building some thing for it
i would get some old tires and put them on the ground then put some 3/4" ply wood over it but then agian im cheap
doogie
SE WI
Yeah, I thought about building something... but I am sure there something out there made for this type of application. I will keep looking around and worse case, rig something up.
EagleStroker
N/A Junkie
Memphis, TN
Our back up has these 8" rubber pads under each foot, that are in turn bolt to a pallet. I'll see if I can track down where they came from :beer:
doogie
SE WI
Awesome... think I will go with 3 of these http://www1.mscdirect.com/CGI/NNSRIT?PARTPG=N2LMSI&PMXREF=Y&PMPXNO=5368259
white05gt
Illinois
My 5hp, 80 gallon compressor is just sitting on three 1/2" pieces of rubber that I cut out of some conveyor belting from work. I have had sitting it on them since the compresssor was new and have never had it walk or move. Instead of spending $56 on the link that SD posted, go to your local asphalt paving contractor and they will probably be willing to cut a used piece of belt for free and it will be almost the same thing.
doogie
SE WI
Thanks. My computer did not like it earlier. That mat seems like a much better idea.
US-1
Banned
The ShadowLands
Works for mine. I've also got it laid out in front of both workbenches. Takes a lot of stress off your feet.
