Can I put my new 4.10 rear axle housing onto a new 5.0?
soliton
Just curious. I just bought a newtakeoff 4.10 axle assembly, and am curious if I'll be able to move that over to a 2011. If I can, the likelyhood that I'll get a 2011 will increase. If not, I'll probably just keep the 07, because I have a lot of cool mods already that I know will not transfer.
popeye
I don't think anything changed in the rear other than higher durometer ratings in the LCA's bushings. Shoud bolt in
hawkeye18
omgwtfbbq
An '11 is going to be damn near undriveable with 4.10s in it with anything less than drag slicks. 4.10s in an '11 is going to be the equivalent of 4.51s in the '05-'09... then there is almost 200lb/ft more of torque to deal with.
Sure they'd bolt over... but you'll lose the street functionality of 1st and 2nd.
SOHC46
Superman
Winder, Ga
200 ft/lbs more torque? 3V's are rated at 320 5.0 4V's are rated at 390 ft/lbs. I have 4.10's in my 05 and first gear is pretty much useless already with street tires. But then again, 4.10's were useless in first gear with my 2V too.
You have to think the 5.0's have a six speed tranny. I think that if you are going to keep it a bolt on car, go for it! If nitrous or a blower are going to go on it, then 3.73 or 3.55 depending on hp levels. 5.0's with weight reduction, big n littles, and a gear, and a tune will probably be high 11's.
TO THE OP: As far as I know everything with transfer. I would not know for sure until I see one.
Vapour Trails
The Renaissance Man
Winnipeg, MB, Canada
He's likely taking account of the gearing too.
4.10s in the new 6-speed would just be retarded.
The max. speed you could achieve in each gear would be:
1st 37 mph
2nd 59 mph
3rd 79 mph
4th 101 mph
5th 134 mph
Even with a stock car, you'd be crossing the traps in 5th and up shifting every 20 mph or so. It would just be annoying and not make you any faster.
19COBRA93
Ford Racing
Clinton, Ut
4.10's and slicks in the '11 are going to be the bees knees.
On the street though, might be a bit steep, but it rev's to 7k so there's some RPM to play with.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
the auto with a 28" tall slick will be nutz, no stall needed
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I've been running 4.10s with a twin screw for 4 years. I can assure you that my car has a shitload more torque than a N/A 5.0 will have. And while it's certainly drivable on street tires, I prefer drag radials for daily use. Much more predictable.
Summerland
... how are a set of 4:30s going to do in an 11? I have a brand new set I got cheap but never got installed. I was considering putting them in my 11 when I get it but after reading this im thinking maybe not?
hawkeye18
omgwtfbbq
The higher gearing ratios in the '11s transmission (with 4.10s out back) get you an equivalent of 4.50s in an 05-09 as I said earlier. 4.10s on an 05-09 are equivalent to 3.73s on an '11. Do you think your car would be drivable with 4.50s out back?
You would have an equivalent to 4.72s out back for an 05-09. Your car will have a top speed, in 6th, of like 23 mph. Of course that's not true, but you get the point. It would be ridiculous. You'd have to buy new tires every 500 miles...
hawkeye18
omgwtfbbq
Yeah, I meant 70... I'm really not sure where I got 200 from. I think I was comparing it to my SHO (which has 200lb/ft of torque).
ArizonaGT
Road Course Member
Phoenix, AZ
Fill in the blank:
4.10s:eek:verkill::4.30s:___________
CarbonRight
Going for broke
Galveston, TX
1st 37 mph
2nd 59 mph
3rd 79 mph
4th 101 mph
5th 134 mph
What size tire is that with? To me it seems like if 5th in these things is the 1:1 gear then you would be wanting to trap as high in 5th as possible, so as long as you're not trapping above 135 4.10's would be just fine.
19COBRA93
Ford Racing
Clinton, Ut
My thoughts as well. I don't think 4.10s are going to be that bad. Sure the trans is geared deeper but the engine also revs higher. I still think it'll be a nice combo.
don_w
San Diego, CA
What are the gear ratios for an '11 automatic?
AlloyGT
Lurker
Highlands Ranch
Optional 6-speed automatic
Gear ratios
1st 4.17
2nd 2.34
3rd 1.52
4th 1.14
5th 0.87
6th 0.69
Final drive 3.15:1
Standard 6-speed manual
Gear ratios
1st 3.66
2nd 2.43
3rd 1.69
4th 1.32
5th 1.00
6th 0.65
Final drive 3.31:1
hawkeye18
omgwtfbbq
AT ratios are:
4.17
2.34
1.52
1.14
0.87
0.69
I don't know what the 5-speed auto ratios are. The rear gearing is 3.15 stock. But yeah, check out how steep that first gear is!
Gene K
Every ones got an opinion but I would gear it to trap in 4th.
That means 3.55 or 3.73 depending on density altitude.
If you gear it to trap in 5th you need either 4.56 or 4.88.
2nd is 2.43 which is the same as 1st in a Top Loader 4-speed.
If you gear it this way I would not be suprised if the car is quicker launching in 2nd.
1-2 shifts at 45' are awful early.
3.66 x 4.88 = 17.86
Thats the same as a 5.28 in a 2010.
PS I ordered my car with 3.55 since I run at a DA well below sea level in the winter.
