Mastering the art of the S197 3 link suspension (sixty foot)
chad05gt
Lake Charles, La
Chad are you spinning? out of the hole?
Yup, something still isnt quite right... its been my EVEREST.
I really think my relocation brackets are welded not quite correctly, thus may be why my TR6060 does 'work' with 3650 driveshaft...
Something geometrically isnt jiving back there; may be the 'twisty' suspension set up as a whole.
Im going to get a good go over of relocation brackets, welds, ds, etc. during build... BUT, will be going back with GT500 SPortlines and 14" Saleen brakes w/ 20" ADR's (so I can have some DR's... damn 19"s..).
So, the front skinnies will go; or NOT go anymore...but, thats just where the car is evolving. :beerdrink:
TurboPete
Miami, Fl
1.40 60ft
Steeda Lwr Billet Control Arms
Metco 3rd adj link
Steeda Adj Drag Suspension
Coil Over Frt 225# rate
Coil over rear 162# rate
D-Spec Coil over Frt Strut
D-Spec Rear Shocks
Steeda Hardcore AntiRoll Bar
BMR Panhard Brace
BMR Adj Panhard bar
CHE Axle Brace
3.27 Rear Gears
325/50/15 Mickey Thompson Drag Radials
4R70W ATF Stage 4 Tranny
3400 PI Multi disk converter
2 step set at 4100
Launch Boost 10#s off the Trans Brake.
Pete
TR3650 Tranny
- Shocks -stock
- Rear springs -steeda sport
- Lower control arms - steeda adj lca
- Upper control arm - steeda street/strip uca
- posi -detroit truetrak
- Pan hard bar steeda adj
- Pan hard bar support brace - steeda
- Gear size - 4.10
- Brand/ tire size - MT ET SR II 265/40/18
- Clutch or which converter at what stall? Spec 3+
- Anti roll bar or which rear sway bar -Steeda Rear Sway
Also Steeda LCA Relocation Brackets
60s typically 1.6-1.7x, best est @ 1.59 (clocks not working)
Suspension set up by Dan Carlson @ Realspeed Auto. Car has always launched well.
Sweet spot with the set up is a 4700 launch with the tires at 17psi
San diego
Shocks/struts - Stock
upper control arm-stock
lower control arms - non adj stang suspension ( i know I need to change)
pan hard bar-steeda
pan hard bar brace- steeda
gears- 4:10
wheels- jegs stars ( thanks to post for wheel fitment)
front skinnys with m/t 26x4 1/2
rear m/t 26x15
clutch- stock
springs- ford racing
steeda rad/sway bar delete ( swar bar still on car)
best time: 1.6 60ft 7.965 in the 1/8th
AlbertD
Tucson, AZ
- Shocks - Stock
- Rear springs - Stock
- Lower control arms - Steeda non-adj w/ BMR relocation brackets
- Upper control arm - J&M non-adj
- posi - Stock
- Pan hard bar - Stock
- Pan hard bar support brace - Stock
- Gear size - 4.10s
- Brand/ tire size - 26x4.5x15s MT ET fronts and 26x11.5x15s MT ET Streets
- Clutch - Exedy Mach 400 w/ Fidanza Steel Flywheel
- Anti roll bar or which rear sway bar - stock
Mid 1.6s launching between 5500-6000 with some spin through first.
jroc07gt
its orange not yellow!!
hammond,la
stock shocks
bmr front and rear springs
bmr lca's
bmr adj uca
bmr anti squat brackets
bmr adj panhard
front sway removed
ph 1 pc ds
stock clutch
4.10s
heavy 03 cobra replicas with 275 40 17 555r's
cut a few 1.68-1.69 but avg low 1.7s leaving at 5200 cuz my pressure plate wouldnt allow me to go any higher
gonna try a bigger rear sway with adj end links when i get the money
dragpac
easton,pa
1.57 60'
STOCK upper
BMR lca&relo brackets
QA-1 set on 3
EATON posi w/4.88's
welded axel tubes
SUMMIT rims 15by8"
GOODYEAR 15by9 slicks @13lbs
CJ drag springs rear only
6500 rpm launch
STOCK clutch&drive shaft
race weight w/driver 3550-3600lbs
bmr
Konablue10Gt
Towson, MD
1.51 60 ft 5-spd
Stock front K mem and rad support
Removed front sway bar
Stock trans and clutch
Alum d/s
Steeda Hardcare upper
UPR nonadj poly lowers
No relocation brackets
Adj panhard bar
Rear springs with 3/4 coil cut
Qa1 single adj rear shocks
Stock axles
Trac Lok polished with extra clutches
4.56's
15x9.5 Weld R/t's
28x10.50 Et drags stiff side wall around 12 psi
Launch 5000-6000 depending on conditions
chad05gt
Lake Charles, La
1.51 60 ft 5-spd
Alum d/s
Adj panhard bar
Stock axles
4.56's
15x9.5 Weld R/t's
I could swear I was able to launch better before I f'd with those things....
Great times, as usual :wtf1:
Pumpkinfish
Johnny Quarter Mile
Schwenksville, PA
- Shocks - Koni Yellow adjustable (all 4 corners)
- Springs - Vogtland front / CJ rears
- Lower control arms - BMR non-adj w/ BMR relocation brackets
- Upper control arm - Steeda adj
- posi - true-trac
- Fays2 Watts Link
- Gear size - 4.10s
- Brand/ tire size - 275/60R15 M&H Rears / 185/75R15 M&H Fronts
- Level 10 5R55S with billet converter
- Anti roll bar or which rear sway bar - Progress Group rear sway bar
Mid 1.5s launching between 2000-2200
zuritausmc
I love Red Bull
Escondido,CA
- Shocks: Stock
- Rear springs Ground Force
- Lower control arms BMR spherical
- Upper control arm Stock
- Pan hard bar BMR
- Pan hard bar support brace Stock
- Gear size 3.31
- Brand/ tire size MT Drag 28x11.5x15 @ 15 psi
- Clutch or which converter at what stall? Stock Converter
- Anti roll bar or which rear sway bar Stock front and back
60 = 1.735 2000 launch
ChevyKiller
Preferred Internet Drink
- Shocks - QA1 single adjustable rear
- Rear springs - Eibach Drag Launch
- Lower control arms - Metco race
- Upper control arm - racecraft
- Spool
- Pan hard bar - Steeda adjustable
- Gear size - 3.31
- Brand/ tire size - 29x12 Goodyear Dragway Specials
- 4000 stall converter with TH400 trans
- BMR extreme Anti roll bar
- QA1 Coilovers in front
- BMR tubular K-Member
- BMR Tubular A-Arms
- Fore Billet Diff Cover
- Currie built rear with 9" ends, 40 spline gun drilled axles, and 3650 yoke
1.21 60' - have not backed it up...yet
Multiple 1.29 60's
GIG4FUN
Rock 'n' Roll Moderator
Iowa
- Spool
- Gear size - 3.31
Multiple 1.29 60's
holy shit... that had to be a rush :thumb:
Redfire
1.47 60'
- Shocks - Fronts stock / rear Tokico
- Lower control arms - CHE
- Upper control arm - CHE adjustable
- posi - Detroit Locker
- Gear size - 3.73
- Brand/ tire size - MT 295/45/17 Drag Radial
- Clutch or which converter at what stall? - PI 3700 / 4R70W
- Anti roll bar or which rear sway bar - Stock rear sway bar
- 2 step set at 3300 using foot brake
- Stock front tires and wheels. Stock rear wheels widened 2"
TungstenGT06
Morrisville Pa
- Shocks - Front/Rear Stock
- Rear springs - CJ springs Front/Rear
- Lower control arms - CHE with Relo brackets
- Upper control arm - Stock
- posi - Stock
- Gear size - 4.10
- Brand/ tire size - M&H 275/50/17 @ 18psi
- Clutch or which converter at what stall? - Stock converter. PTC going in now.
- 1500 to 1750 RPM launch. Stock 18" front wheels.
Best 60'- 1.559
__________________
LAK3RS
Original Member
DFW, TX
- UPR Swaybar Delete
- BMR Non-Adjustable A-Arms
- CHE Adjustable Poly Upper Control Arm
- Stock Upper Control Arm Mount
- CHE Tubular Poly/Poly Lower Control Arms
- CHE LCA Relocation Brackets
- CHE Adjustable Poly/Poly Panhard Bar
- CHE Panhard Brace
- Stock Rear Swaybar
- Stock Struts
- Stock Shocks
- Stock Springs
- Stock Differential
- FRPP 4.10 Gears
- Spydershaft
- Stock Converter
- Nitto 555 295/45/18's
High 2.0's-2.1 60 ft's (Yeah, I've never gotten out of the 2.0's! Even when using ET Streets)
Launch at idle
weeloGT
Little Rock. AR
awesome thread matt!!!! im getting ready to order the final pieces to complete the rear end and hit the track within the next 3 weeks, work has kept me from it up to this point but im tired of wearing out a perfect set of drag radials just driving around town
antonio1988
Redline: 8600rpm
Miami, FL
Two quick question while on this topic... first, I have CHE Relocation Brackets waiting to be installed, do they HAVE to be welded or will I be just fine just having them bolted in? Second question is, when swapping back to stock springs (I have CHE LCA's, Steeda Adj. UCA, UPR Adj. Panhard), what setting's should I use for my D-Specs (with 17" ET Streets on the rear and 20s on the front)? Thanks guys, just trying to hook by spraing out of the hole
