470 GT/CS
- Joined
- Apr 7, 2009
- Posts
- 1,218
- Reaction score
- 6
Thanks, some people on another forum that I posted this on wanted to know.
Within their engineering and budgetary restraints. The aftermarket is not constrained by interior noise limitations or bean counters.
Interior noise limitations? You do realize they have been putting a tube from the intake to the passenger compartment for a few years now to raise the level of noise right?
Definitly a huge difference in airflow with the C&L. The question is how much extra cfm do you need? At 28in the 2011 is flowing about 750 cfm. Will a stock motor pick up from an extra 400+ cfm? I guess we will find out
Back in the dark ages (mid-'80's) I got my AAS degree in fixing cars. Part of the degree had to do with airflow in engines. If I remember right, the instructor made a big deal out of 'over-carbing' engines. As in, small blocks didn't need more than a 750CFM carb as they don't flow that much air anyway...
A quick poke around with a search engine came up with this:
http://www.dsmtuners.com/forums/bolt-tech/142866-cfm-per-hp.html
http://www.speedwaybids.com/calcs/powerfromcfm.html
In the end, a specific CFM number is no good without qualifying what standard was used, i.e. temps, pressure, etc.
I really find it hard to believe Ford would make what appears to be a world-class engine just to stifle it with an crappy airbox/filter setup. So until we get dyno/drag strip proof on tuned stock airbox/CAI setups, we are all just armchair racing...
If you ask me, I think Ford is doing the most inovative work right now. Think of the monumental task of beating GM at the power game, yet making the engines robust enough to put up with what I lovingly call 'redneck-abuse.' You know, cold starts taken right to redline, changing the oil once a year whether it needs it or not, etc. To make these engines survive that abuse and still come close to 1hp/liter is pretty spiffy in my book...
Brian
