Bullitt #2479 Build
GrnBullitt08
Dale Jr
Northwest Indiana
New Spec Clutch
Motor and Trans
Motor installed
GrnBullitt08
Dale Jr
Northwest Indiana
Congrats it still won't be the same since it isn't fi but your heading back in the right direction
Yeah it will be lacking alot of power but it's just nice to be able to drive it. I'm gonna have BBR retune it so it will still have some power. It has mild bolt-ons still, and I plan on adding cams and my ported heads once they return. So it will still be a mid 12 sec car after I'm through with it.
GrnBullitt08
Dale Jr
Northwest Indiana
I will be finishing up the rest of the install tomorrow and I will have pics of it out and cleaned up hopefully. I'm getting a check engine light so I'm guessing the oil that soaked the 02 sensors when the motor blew ruined them.
BubbaRATM
bottle fed baby
West Monroe, LA
very possible, try cleaning them with brake cleaner real good. might be able to save a few benjamins.
G
GTStang08
Guest
dude very nice!!! sounds like the o2 got crap in em, cause it shouldnt go off that fast when just starting the car
G
GTStang08
Guest
brake cleaner is good stuff my old man showed me that as well....if not just turn the o2's off with the new tune....if your going to keep the car and not put boost on it ill sell you my steeda UDP's in june...
PUNISHERSTANG
Patrolman
nap town
most brake parts cleaners arent sensor safe but 02 sensors are tough mofo's given the heat and raw fuel they are exposed to. its your call
Sent from my Droid using Tapatalk
BubbaRATM
bottle fed baby
West Monroe, LA
I used brake cleaner on mine when i swapped to my o/r x, mine work fine, i just hosed them down inside and out and blew them out with air compressor and put anti seize on them and right back in.
i may be lucky but i cant see it being that unsafe because it evaporates so fast.
