Bullitt #2479 Build
05stroker
Never enough power guy!
Bullard Tx.
I have the CHT jumper coming from the CHT sensor plugged into the a sensor that sits on the back on the intake manifold.
Is that the wrong one? There is alot of bullshit back there that looks the same, it is possible that I could of swapped one.
The cht sensor plugs into a short extension wire that plugs into the main engine harness . There is another plug that plugs into the cmcv plates. The way you describe , it sounds like your cht sensor is plugged into the cmcv plates.
NastyStang113
Made in U.S.A.
Central Florida
I agree... Like Stroker says the CHT sensor plugs into the head and than goes to the harness. What jumper? Might want to pull that intake manifold off!!
GrnBullitt08
Dale Jr
Northwest Indiana
Yes, that would explain both error codes as well....Im a dumbass.:rant:
GrnBullitt08
Dale Jr
Northwest Indiana
haha....yeah. I mixed the wires up big time. I deserve this:asshat:
I got a little excited and put them in the wrong place in the mist of all the engine repair. Those two tie-ins have the same connector like 05stroker said.
05stroker
Bullard Tx.
There is a section of wire that is about 8 " long that goes from the harness to the cht sensor .
05stroker
Bullard Tx.
That's ok . That's what we are here for , to point out your errors. LOL
GrnBullitt08
Dale Jr
Northwest Indiana
Yup thats it. I plugged that into the CMCVs instead of the other connector that it needs to be in on the main harness behind the manifold....I'll take a look at it tomorrow and see if that solves the problem. Thanks guys.
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
I was a week away form ordering n20 and saw a nitrous backfire first hand at a dyno day and seeing his car on fire and everything toast I said ill get a screen and nav instead and save up to turbo@!
BubbaRATM
bottle fed baby
West Monroe, LA
lol, i have seen them too. i have also seen people's parachutes not open and that doesn't scare me from jumping. Its alot to do with safety and procedure. I will agree that luck sometimes becomes a factor. I would like a turbo set up also but don't have the cash for that right now.
GrnBullitt08
Dale Jr
Northwest Indiana
lol i hope they arent that sensitive, im hoping to have 100 shot on mine next week.
Goodluck with the N20, should see some good power gains. You have a tune ready for it too I hope and some new injectors?
n20 can do a # on a not sensitive car!!
Yes it can...
Yeah going forced induction is the way to. Nitrous has its pros and cons but can tear a motor up quick....but so can a blower without the right setup.:yuck:
