NastyStang113
Made in U.S.A.
The cylinder head temperature sensor plugs into the head since it's a cylinder head temperature sensor. LOL
The cylinder head temperature sensor plugs into the head since it's a cylinder head temperature sensor. LOL![]()
The cht sensor plugs into a short extension wire that plugs into the main engine harness . There is another plug that plugs into the cmcv plates. The way you describe , it sounds like your cht sensor is plugged into the cmcv plates.I have the CHT jumper coming from the CHT sensor plugged into the a sensor that sits on the back on the intake manifold.
Is that the wrong one? There is alot of bullshit back there that looks the same, it is possible that I could of swapped one.
I agree... Like Stroker says the CHT sensor plugs into the head and than goes to the harness. What jumper? Might want to pull that intake manifold off!!
There is a section of wire that is about 8 " long that goes from the harness to the cht sensor .I agree... Like Stroker says the CHT sensor plugs into the head and than goes to the harness. What jumper? Might want to pull that intake manifold off!!
That's ok . That's what we are here for , to point out your errors. LOLhaha....yeah. I mixed the wires up big time. I deserve this
I got a little excited and put them in the wrong place in the mist of all the engine repair. Those two tie-ins have the same connector like 05stroker said.
A "sensitive" car for sensitive guys.Damn I hate all these sensors lol.
lol i hope they arent that sensitive, im hoping to have 100 shot on mine next week.
Yes it can...n20 can do a # on a not sensitive car!!
I was a week away form ordering n20 and saw a nitrous backfire first hand at a dyno day and seeing his car on fire and everything toast I said ill get a screen and nav instead and save up to turbo@!
