08nastygt
Thanks I got 60 miles on it and all is well. I'm going to tighten everything down tomorrow and change the oil.
What do you mean by it was all loose?
yes, do tell
Heat relieves stress in steel (stainless, carbon steel, or whatever) and can loosen fasteners on the hot side. When you tighten everything up, generally there is stress on the piping but as it gets hot, it relaxes and the hardware loosens up. A good once over after driving (heat cycle) and a re-torque is usually necessary.What do you mean by it was all loose?
YaaaaaYou started losing power after 5600? Something is wrong there.
