New Build Thread:
tommygodfrey
JPC Sales & Tech
Maryland
very nice. i would love to convert my air to air ic to air to water but i would like to leave it up front like yall do with the procharger kit. do yall offer that for the hellion kit
It's the same intercooler. You may just have to move some pipes around. We went with the PT2000 on this car for the future. Our front mount is only available as a 1250hp or 1500hp rating. The one in this car is 2000hp
tommygodfrey
JPC Sales & Tech
Maryland
Nice
Now the work begins on the 25.5 cage :)
Ummm Undercoat. :(
tommygodfrey
JPC Sales & Tech
Maryland
so do yall make one that will bolt exactly where the ic goes for the hellion kit with the same side entrance and exit
We could probably have it modified to do that, just flip it the outlet. Or you can do new piping
looks very cool, but wont the cooler make a lot of noise being inside the car?
It might but it's mainly a race car.
tommygodfrey
JPC Sales & Tech
Maryland
man that would would be awsome. do yall use just a tank in the trunk. what is the set up exactly.
We use a 5 gallon cell in the trunk. We've used the Meziere pump and on this build we're using the Hugh Precision pump ( which is basically a pool pump ) basically some hose and fittings. We usually use the aluminun cells and modify the tops for a larger lid instead of the regular fuel cell lid.
ChevyKiller
Preferred Internet Drink
I know they say it's 'rated' for 2000 hp, but no way are you even going to see 1200 hp with that PT2000 through a 3V set-up. (with low IAT's anyway)
That's the one I sold and at 1100 rwhp, I was seeing IAT's at 150º cross the stripe and I had a humungous 16 gallon resevoir attached to it. My new one dropped the IAT's almost 100º!!!
Good luck, but if you go for big power, you may find that cooler lacking in that car.
EDIT - see next post
