BubbaRATM
bottle fed baby
yes but i play on the street alot so the nano would be better i think.
Huh ? You have a zex controller and a HSW plate ? That could be your problem right there.
Why?
Why?
im not using any controller, just the zex box injecting at WOT
ok got ya, i thought you were meaning a TCS controller. i doubt that the zex box would be effected negatively by the plate.
So you don't have a window switch either ?
nope at the track i will have my et street radials on and i want it to spray off the line and all the way down the track.
May the force be with your transmission.
i think it will be fine, and if not well then that means it needs upgrading.
First, like previously stated you need a pressure gauge and the right bottle pressure (usually 950psi to 1050 psi). Everything else doesn't even matter if you don't have the right pressure to start with. I picked up 34 rwhp going from the wrong pressure (around 800 something) to 1000 psi. And that was on a 100 shot.
Second, I really would suggest a window switch if your going to squeeze out of the hole. 3 years ago I didn't have one, and was fine for 100+ nitrous passes, then one day.....
Wow that is one hell of a backfire.First, like previously stated you need a pressure gauge and the right bottle pressure (usually 950psi to 1050 psi). Everything else doesn't even matter if you don't have the right pressure to start with. I picked up 34 rwhp going from the wrong pressure (around 800 something) to 1000 psi. And that was on a 100 shot.
starting to think i should sell this car and buy a damn camaro, tranny is ok for 125 shot and so is the motor, they make more power stock, parts are cheaper...
ok so now anyone want to chime in and tell me their experiences with these transmissions?? how weak are they and what power level can they hold?
Transmissions seem to be pretty strong im running 500 rwhp, and I even have stock clutch! just trying to get my money's worth before I switch it, the clutch is the week spot but if been told the tranny can hold alot more than im throwing at it? but I guess ill find out one way or the other.
