2011CS
2011 California Special
- Joined
- Apr 25, 2010
- Posts
- 215
- Reaction score
- 3
Just kidding!
hahahahahahahaaaa
Sorry couldn't resist
hahahahahahahaaaa
All right damn it I'm going to start taking heads if people don't stop with the BS numbers - Dirty Harry style.
its funny how all the known tuners always talk about putting the wideband as close as possible to the engine.. that diablo would be using a sniffer up the tailpipe..
Man at least let us know what you can change or give us some kind of info, we're dieing over here.
Actually the wideband is as close to the engine as possible here at Diablo. And there is one in each bank. They are factory in this car and it's best to tune by the factory widebands since that is what the car is going to use for closed loop WOT fueling.
The tailpipe sniffer is there just for a quick easy reference on the dyno graph. And if you are interested, it matched the factory widebands very closely.
Ken
Ken... are you saying the new 2011 uses wide band O2 sensors? Also, it uses these WB's in a "Closed" loop WOT mode from the factory?
Ken, do you know if it might be possible, given enough capacity of injectors and fuel system to create some flex fuel tunes for E85 because of the widebands???
E85 Tunes shouldn't be a problem at all
Open the gas door on your car and you will see on the inside a circled E85 logo with a slash thru it. I'm not sure why Ford would go to the trouble to basically say no E85 for this car at all considering its just a matter of changing the calibration but I'm sure they have their reasons. I'll poke around and see if I can find anything out because I love E85.
JJ
We can change everything! That is what is going to separate one tune on these from another. I can throw together a tune with some global spark added, rev limiter raise and a couple of other things and look like a hero. But the fact is there are a tremendous amount of things to tune on this car if you want it done correctly. A mind blowing amount of spark tables due to the VCT, all the VCT control stuff. etc etc. When we release a tune it will be done right I can assure you of that!
Can you give us any idea about what increases in performance you have seen just adjusting the regular settings you mentioned above without messing with the vct yet?
If not numbers how about a seat of pants assesment?
have you been able to get the a/f ratio to a flat 13.x?
When i dyno'd mine i was soo lean until 6k and then at the sudden a little fat, was wondering if there was any more low end torque to be had by adjusting this and if turning off any tq mgmt or anything else has granted any extra torque on the low end.
