First look: 2011 5.0L Clutch Assembly & Shifter
carbd86gt
Lethal Performance
South Florida
The new 6 speed is actually shorter, but I haven't measured it to confirm that, but just eying it looks to be about 9" or so shorter. Here is a picture for reference, the McLeod box is 16" long, so I don't think a 05-2010 D/S will work, but we are going to try to test fit one to confirm also...
luillo
Fort Walton Beach, Florida
i don't know if anybody has asked this question before but for the looks do you think the transmision could handle a lot of HP and torque?
fdjizm
Drag Queen
Right, rated for 375 lb/ft and the motor makes 390 lb/ft....I find that quite curious (that the trans has a lower torque rating than the motor actually makes).
Kind of like the camaro, trans rated at 430ft-lbs per GM documentation...
right on the edge of it's torque rating. weird.
lostsoul
2014 vett or 2015 stang..
Gay Area
"The new MT82 manual is designed by Fords JFT joint venture with Getrag in Germany and built in a four-way joint venture plant in China."
sad.. means engineered good, but built by starving kids with lead material.. haha..
