n e 1 know the part #'s for arp longer wheel studs?
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
just to be legal like i ordered some open end lugs from summitt for my race stars. figure i need studs that are about 1" or so longer than stock
anyone have the front and rear part #'s?
Konablue10Gt
Towson, MD
I can say with 100% certainty, that the ARP 100-7722 3in fronts fit perfect. You dont even have to pull the brakes off. Just spin the rotor in the right position, use a hammer to punch it out the back, soak the knurl or the ARP's with some WD-40 then use a large hardened washer and an open ended lug nut to pull it back through.
Konablue10Gt
Towson, MD
The ARP ones fit with no mods. You can use the cheaper Summit ones or Jegs 65110 for the front but you will have to drill the hub to fit the larger knurl.
beefcake
Official Vendor
Bethel, Ohio
after talking to jegs, it appears the part # i found "using search" is not the proper part #, it is one # off from the original ones you posted.
i would prefer to use the arps, but man, they are expensive
joedls
Dragracer wannabe
Lake Forest, CA
i know, i just think the nearly 6 fold price increase is ridiculous for the newer mustangs
I assume they price it that way because of its unique knurl size. Since it's probably unique to Mustangs, there isn't enough of a demand to drive the price down. That would be my guess anyway.
