Race gas
Teege24
Mchenry, IL
Hey guys I couldn't find anything about race gas in the search but heres my question..if i have a 93 octane tune would it harm my car putting 100octane race gas in the car?..im thinking yes cuz my tunes specifically for 93octane but i figured id ask
Kobie
Nope. You can only use as much of the octane number as the car "needs".
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Octane is merely an "anti-knock" number. Putting in 100 on a 93 tune will decrease the chance of detonation, but won't necessarily increase performance (unless your knock sensors have been pulling timing on the 93 tune).
Teege24
Mchenry, IL
thanks, guys and reason for using it is my buddy has some lying around and i kinda just wanted to throw some in my car to see if it did anything...i just dont want my car to blow up cuz its not tuned for it lol but if im not gonna get any noticeable performance outta it i dont think its worth it
Miracle
"Shall not be infringed"
Clarksville, TN
Say good bye to your 02 sensors after filling up though. ;)
Not really... they do make unleaded 100 octane fuel, no need to worry about the O2's with that.
Apparently you missed it:
Unless you change the tune, or are having knock issues with 93, then there is no reason to try to use it... you won't get anything out of it.
BlownAway05
still too slow
Orlando, FL
your car will run leaner as the stoich for 100 unleaded is less than that of 93 (i.e. you will need more fuel per air)
RedFire07GT
11sec N/A 3V
Ocean County, NJ
will not harm it, i use 109 at the track and my race tune is set for 93... I only put higher octane in so i can mess with the timing on my car while im racing.
Brandon
07TwinScrewdGT
FUEL SLUT
Orlando, FL
You CAN run UNLEADED 100 Octane on a 93 octane tune and like someone said before you may not see a performance gain unless your car is pulling timing BUT it WILL give you extra protection against detonation especially if your boosted but if your n/a i wouldnt waste the gas... I run a couple a gallons of 100 octane with my 93 octane tune on the weekends just for the extra protection cuz its so hot right now here in florida that my intake temps are running a little high thus increasing my chance of detonation so i use it as a precaution when im doing ALOT of racing on the weekends.. Also during the week (Its my daily driver) I load on my 91 octane tune but the car only gets filled with 93 octane for the same reason just extra piece of mind...
Kuro!
Banned
Austin, TX
What fuel is it exactly?
Race fuel is a generic name; you can run anything from C16 to VP Import...
And FYI, if the jug has been opened for some time it's probably no good. Old race fuel sucks...
DirtyDogOfTheDesert
Canada/Yemen
There is also the stoich point of the fuel to consider. It could run leaner or richer depending on how different to stoich point of the 2 different fuels are.
VP MS109 for example runs almost a full point leaner than pump gas. Running that without being tuned for it could cause problems if you're really beating on the car.
