Saleen Lower Control Arm Bushing Replacement???
jasongt06
I just got a set of Saleen Lower Control Arms and they didn't come with any of the bushings so I need to order some. Does anyone know what bushings I need so that I can use these? Thanks
stang389
texas
call steeda they make a bushing replacement kit might work with what you got
jasongt06
I emailed Saleen and all they told me was that these were discontinued and they didn't have any bushings.
Ken04
gm troll basher
Santa Rosa Ca.
measure the throat and the width, then call around. There are several vendors here who sell lcas, I'm sure one of them will be happy to help you find bushings that will fit. Saleen out sources their parts, if you could find out which company made, or still carries your lcas even though Saleen discontinued selling them it would be easier to find bushings. Someone here said they look like BMR parts. Did you try them ?
Barricade
Decepticon Extraordinaire
The Alamo
I saw those on ebay as well....like $15 right?
I dont see an offset on them though....
jasongt06
There is an offset on them. I have emailed BMR to see who made them but I have heard back yet.
Ken04
gm troll basher
Santa Rosa Ca.
the opening inside where the bushing would go, and the width of the collar the bushing would sit in.
See the holes in your lcas where bushing used to, and would normally go ? There would be a good place to get some measurements. If you want to find some bushings that would fit in there that is,,,,,,,,,
jasongt06
I measured the arms and on the small end the tubing length is 1.5 inch and the width is 1.75 inch. The big end is 1.92 length and the width is 1.75.
