graygt07
I installed jdm's 302E in am car one month ago. I just swapped everything over. I got my 1000 miles and had the car dyno tuned. I even took it to the track once. Yhe car ran just fine no problems. Then I desided to drop a pulley size on the saleen and add 60# injectors. Went to the place I that tuned the car when it had a stock motor. They dyno tuned it and when I took it out for a test drive I got about 1/2 throttle and it started to ping so I got off it and it was blowing white (not blue) smoke out of the pipes. I turned around and went back to the shop> it didnt get any hotter and my oil pressure was good.They pulled one of the back plugs and it had oil on it. The injectors should be ok they were new and it should have showed up on the dyno if something was wrong with one of them. I would have to guess that something had to be wrong with the tune? I had 1/2 a tank of 93 gas and the car ran fine on the way to there shop.
Give me some ideas on the problem.
1. head gasket?
2. piston ring?
3. something in the valve train?
4.
please help
1. head gasket?
2. piston ring?
4.
please help
