HOLYWD's build 20**
HOLYWD
S197 Junkie
2010 spring build
Thanks Josh !
I dunno Alex , your the Jew , you tell me ........
alexthejew
Jewish and lovin it.
thats what ive always thought to be true. i say, keep high octane in there, keep the peddle on the ground, and then clear the code.
HOLYWD
S197 Junkie
2010 spring build
Its idling like shot though , like to where it wants to die almost
Redfire_WNL
THE BEAST UNLEASHED!
TAMPA, FL
Did you crimp that vacum hose when heating it up with the heat gun on the manifold because I found out the hrad way when I crimped mine and my car would just sputter and then shut off almost like if I out a bag over my CAI.
Redfire_WNL
TAMPA, FL
Heating it ?
You know where you have to cut the one vacum hose and then re-fit it on one of the nipples of the side of the new manifold going into the driver side valve covers.
When you put on the new manifold that hose is to long so you had to cut it right so it would fit on the new manifold without crimping it up.
HOLYWD
S197 Junkie
2010 spring build
So just tried to start the car
Starts runs
Then the throttle starts getting jumpy sputtering then strts to act like it wants to die when I turn it off .... Grrrrrr
Tune maybe ?
HOLYWD
S197 Junkie
2010 spring build
Hm I wonder where
I'll have to find it tomorrow
HOLYWD
S197 Junkie
2010 spring build
K blew out the motor a little
Put some injector / gas cleaner in
HOLYWD
S197 Junkie
2010 spring build
Lol semi crappy
Pulling everything apart after lunch to look for leaks
