Matt D
S197 Pilot
So... Last night I sat down for 10 mins or so and thought... Can my car get down to pure street weight is it really possible Matt
Ok now most guys are super top secret about this kinda stuff. I like to share with my S197 homies think im looped or not xD , I am usually pretty realistic about this kind of stuff.
My car currently weighs 3060 lbs so... I need to remove about 60 lbs before the cage goes in (6 point wolfe weld in)
Manual rack from stock rack and res minus 10-15 lbs
Remove centre console/arm rest minus 30-35lbs ( I did weigh this sucker once)
Remove carpet and scrape sound deadning floor and trans tunned along with carpet mute minus 20-25lbs ????
Rear end- shortning .75-1" with 33 spline gun drilled axles and 9" ends (no loss no gain)
Rear drag brakes compared to stock minus 25 - 28lbs
Remove rear seat delete (wood shit) minus 10 lbs
remove corbeau harness minus 10 lbs ( add wolfe cage +50lbs)
Make light weight bumper beams (-26 lbs for both) or remove completly up to 32lbs gone
Remove factory speakers ????? (this I don't know yet cause I liek to jam when I cruise) I figure at least 20 lbs for all of them
Going to pull the door skins off and see what material I can muster off the factory door ( probably not much so that's up in the air)
I would like to go VFN Pin on 3" cowl hood ( cowl right to the window) so that's 20 lbs lighter then my current cervinis
Remove wiper arms, motor and hard ware 10-13lbs (if memory serves me right)
Remove the dash and anything that isn't needed is going, Paul said the heater core and shit is about 15 lbs or so
I have so remove the ac lines under the dash so that I don't know about the weight yet???
Now Paul (psfracer) said most of the actual weight was in the factory wire harness and fuse boxes... Right now Im not sure If I want to re wire the car but that's up in the air.
Ditch factory brake lines , re run braided and ditch abs box and sensors minus 10 lbs
Smaller fan (easy 5-8 lbs there)
Gettin more extreme I can put kirky drag seats instead of my corbeau ones and drop aother 10-12lbs but that's up in the air at this point..
So ditch the Evap system complety (15-18lbs) gone there
So from ditching the stock fuel tank and switching to a fuel cell minus 35 lbs (thanks Paul for that info)
Alum act flywheel -8 lbs or so
I had some more info for another few lbs but I forgot right now -_-
What do you guys think? any thing im missing
never thought about that lol
