Lifting front tires at the track
classix_stang289
New Jersey
I have the stock 5spd, 4.10gear, 1peice driveshaft, whipple, LCA and relo brackets, UCA/new mount, going to install CJ springs and QA1 single adj. shocks, and will be switching to M&H slicks when the racestars go on. power numbers in sig
Riptide
Will work for Mustang.
Montucky
Battery relocate probably wouldn't hurt if you're trying to pop a wheelie.
psfracer
billy badass
Valencia, CA
Auto or manual? You know these cars came with 5 speed autos and manual transmissions, so the above comment doesn't help. This is one of the most important factors as you can leave a lot harder with a manual by launching at a much higher rpm then you would with the auto (at your level)---all out racing autos with a transbrake thats a different story
tigerhonaker
TN
This is my friends Bullitt. FRPP Whipple, 4.10 gears, LCA Relocation, 18" M&H's. He has since re-tuned it, put the 3.73's back in, and installed 18" Mickey Thompsons. He just went 1.51 60' 11.18 @ 123 MPH.
My car needs a floor jack to get the front tires off of the ground.
The Bullitt is looking Awesome
tigerhonaker
That was before I put the Steeda anti-roll bar in. With an anti-roll bar it would leave equal.
Post #14 Pics are Awesome Buddy.
Nice .........
tigerhonaker
classix_stang289
New Jersey
5spd manual, my apology
ArtQ
Alpha, NJ
Lightweight front end components, dialed in suspension and sticky tires.
picture.php
picture.php
picture.php
wbt
Mods in my sig.
PNR Welding
Hammonton, NJ
I left at 13psi on the one with the back to camera.
My car made 640 at 16psi, but had a bad leak on the hot side pipe. It wouldnt let me turn the boost up anymore past 16psi.
Chris06GT
Dragging LS A..
Alabama
It doesn't take a lot of power......
My car made 317/340 at the time, I was on Bogarts, slicks, 5 speed manual..... Leaving at 6000 and it would pull the left front about 8 inches....
classix_stang289
New Jersey
F*cking A, Thats what i like to hear. I shouldnt have an issue then lol
mikeysgt
Bakersfield, CA
definitely helps launching at higher rpm's. even off my nitrous launches I don't think I ever lifted the front wheels since I had the stock torque converter and couldn't launch higher than about 2000rpms
