waketek516
Pedal to the Metal!
So I got a sweet deal on here for a basic Zex wet kit. I've searched tons of threads and learned a lot about these kits (thank you again S197 tech). I've decided that I'll run a 100 shot, HT0s, and get custom tuned with my boy Greg at RET in Downey, CA. BAP is a possibility depending on the Fuel Pump Duty Cycles when tuning.
However, with learning - came more questions...
1. I'm going to be running the kit with the TPS switch and a window switch. My car currently has an MSD 2-step, and I'm wondering if there is an issue with that when I'm launching at the track? N/A this past season I was launching the car around 5k (with slicks). That's gotta be close to the voltage that turns the system on through the TPS, and I'm worried that if it cuts spark, I'm going to damage something if its spraying.
2. The kit I got came with a Zex single outlet purge. I want to custom mount everything and may need to run lines longer than what is supplied in the kit. I want to hide the control box, lines, and purge solenoid, and may even try to route the purge so goes out of my scoop. My question is - is it okay to lengthen the purge & feed lines, and what sizes do I need. I haven't worked with AN fittings yet so I'm unfamiliar with recognizing the sizes by eye. I believe my feed line is 6AN and the purge line may be 4AN, but can someone confirm that?
3. I'll also be adding a bottle warmer to the kit along with some gauges (AF, N2O, Fuel). Is there a way to wire the warmer so that when the bottle reaches optimal pressure it shuts off? I know some of the warmers have a thermostat, but I'm not familiar if it reads off bottle pressure or actual temperature.
Thanks in advance for you help on this!
I can't be the only guy running a 2-step and N2O. I'll talk to Greg as well and see what he thinks when I get closer to tuning. (I'm still saving up for a lot of parts so this will be a really fun & safe kit.)
I'll post up some pics later of what parts of the kit I have so far.
