Gear Oil? (I know)
gmantheman
Escondido, CA
I went off the recommendation of a local shop that specializes in gears and they recommend dino oil for gears. In a local forum another mustang shop owner specialist says to used synthetic because of the clutch packs. So, should I be using synthectic because of the clutch packs?
Riptide
Will work for Mustang.
Montucky
Depending on the brand/type of gear oil you don't need the friction modifier either. I know the valvoline synthetic stuff states as much in their documentation.
mrdeath2000
Surprise, AZ
the sticker on the diff cover says "Synthetic Only".
I use 75w140 RP (with modifier already in it), but I also live in Phx, AZ where it gets MFN Hot! :)
Wicked97
Beltsville, MD
If you read the royal purple bottle it has the fiction modifier already added.
you guys are just adding double.... wasting money
bolted3v
Natzifornia
i know it says "it has it there" already but i still put a little bottle there anyways. 5 bucks aint shit anyways :lol2:
CandyRedGT
Illinois
I had Royal Purple in my car...till i blew the stock posi.....When i put the True Trac in it......they reccomended NO synthetic ever in it.
JPO8GT
USA
Same here changed from stock trac loc to eaton/detroit trutrac Plain 80w 90 lucas
GT E UPP
Toronto, Ontario, Canada
For me it's always been Royal Purplle 75-140 with a bottle of friction modifier.
Better to have all the protection possible for the sake of an extra $5.00....
gmantheman
Escondido, CA
This is the response I got from the shop: When sythetics are used, the friction modifier tends to fall out of the solution quickly. Use regular gear oil. Name brands, good quality. Remember this shop specializes in Gears and Axles.
