06silverbullet
wow it's coming along pretty good.
Thanx, its getting there..... Im hoping next weekend ill be dropping the motor back in... As long as its not snowing..... Man, cant wait to be done with it haha...wow it's coming along pretty good.
Well, maybe if im lucky ill be able to turn the key by the end of next weekend also.... Gotta order new spark plugs though......sweet, i wish it wouldn't rain in cali.... lol how much longer til the first start up?
More's coming tonight and pretty much all day tomarrow.... Actually, I bet your getting hit right now lolWe have more snow coming here.....alot more.....so if you get a chance in the next couple days to drop that motor back in a garage the car I would do it....
Haha, you got it bud... Ill try out my Go-Pro camera I got this x-mas for the re-start up.. Also can't wait to use it at the track this spring/summer along with any street run in's....^^^hope it blows over chicago and pounds down ur state ror!!
hope it stops snowing by u man , i wanna see some vids of this thing running!!
Update?
So know I gotta pick up another slave before I drop the motor in...
Before taking off the slave?Did you tie clutch pedal up before you removed the hydraulic line?
I see what your saying, having it up limits the amount of air that could possibly get in the system.... Yea, once I pushed the pedal in, i was fucked and ill have to bleed it.... I meen, it was leaking bad out of the front seal under the green dust shelid... Its all good, i have a idea to bleed that thing real easy... Just another buck spent after I just ordered the blow through piping/fittings.... Never ends manI pulled my trans and motor at once. When you remove the line you don want the clutch laying on the floor you need to tie it up. When you remove th slave it won't matter because you'll need to bleed the system anyway. I think your in need of a new one anyway... Prob for the better
Yea, I cant wait to see how this RST is...mcleod clutches come with a brand new ford oem slaveand their clutches are amazing i might add.
well if it's anything like the one i bought i stalled the car cause i couldn't feel the clutch at all it was super light. it was well worht the money.I see what your saying, having it up limits the amount of air that could possibly get in the system.... Yea, once I pushed the pedal in, i was fucked and ill have to bleed it.... I meen, it was leaking bad out of the front seal under the green dust shelid... Its all good, i have a idea to bleed that thing real easy... Just another buck spent after I just ordered the blow through piping/fittings.... Never ends man
