Guys, when SCT, Diablo, or anyone else "tunes" and ECU. All they are really doing is changing the values in the xy tables for many different variables that are used to calculate the outputs of the ECU for fuel, spark, timing, etc.
What none of these companies can do is to add colums and rows to those tables. They are hard set limits that would require the very source code that the software is programmed with. I can all but gaurantee that the engineers that created that code aren't giving that up any time soon.
It is a real bummer that the factory ECU cannot run faster than 7800rpm as with the right internals and valvetrain this motor looks to be able really scream at 8000+ with just a little more cam and some mild head work.
