2011 gt times
fiveoh
Not really worried about the time because it's shifting into 3rd right before the 1/8 mile, so I know it's losing some time there. That's why I was asking about the tire. My 1/8 is identical to george's buy I've got more mods?
DA/weather plays a big role in this as well. Where are you located? George is running up north in cold weather still. If your in the south and its warmer/more humidity that will cost you a few tenths.
GeorgeInNePa
Clarks Summit, PA
DA/weather plays a big roll in this as well. Where are you located? George is running up north in cold weather still. If your in the south and its warmer/more humidity that will cost you a few tenths.
I think its more the fact his car has the Boss intake but shift points for the stock intake.
Miavia7
Well the tune is for the boss intake by bbr, but still isnt shifting right. I'm in Mississippi so I know the heat was alittle part in it
DTony
Ohio
My BBR Boss tune wouldnt shift above 7000 in drive and when I tried shifting by hand I kept hitting the rev limiter. I put my stock intake back on for now and once I get everything dialed in I will try it again.
stangdavid
well be thankful your doesn't run like mine. i have the same basic mods as George just different tuner and i ran friday nite and only ran a 8.27 and 8.30 at 87.2 and 87.8mph. but i am in the process of fixing my problems.
