Brake lines
Shotokan1509
CT
I picked up a set of Brembo's, plan to install, paint rear brakes, flush the fluid... started thinking do all that, what about the lines?
Are GT & GT500 lines interchangeable?
Are they the same, or are the GT500's somehow upgraded?
Stainless braided, the Russell's appear substantially cheaper than other options, is this a "you get what you pay for" or the others are just more name brand?
RDK
yes they are the same.. Gregg H. has a set of Russell lines.. Maybe he can chime in ..
ren274u
North Carolina
I just installed Russell lines this past weekend. They quality was real good. Better then the Earls I had on my 06. I also just installed them with the brembo's and they fit fine. Flushed the fluids and installed earls solo bleeders, which by the way are the same as the gt for the brembo, you just need 4 total for the front.
Shotokan1509
CT
Didn't happen to snap any pics did ya?
RDK
I can probably get Gregg to email them to me if you want..
Shotokan1509
CT
I've seen certain lines on various cars that are too long or short, or just flop around
jasongt06
Russell Performance Plumbing is an Edelbrock company. Vic isn't going to put out junk.
Gray Ghost GT
Road Racing Fanatic!
Madison, AL
I use Goodridge SS brake lines on both my road course cars. Excellent quality for a reasonable price.
kevinatfms
EX-ford tech(6 years)
MD
^^^ same here, great quality and have taken plenty of abuse.
gil_t2
Love Nitro in the Morning
Northern Va
Since the lines are the same i would keep the stock lines and spend the money on something that makes HP. If they need replacing then go ahead. I used SS lines on my vette, no improvment, but i needed new lines.
Sam Strano
I sell both Russell and Goodridge, they are not the same. Mostly the fact that Goodridge has all the correct mounting blocks and such, just like stock lines. Russell's, at least the last set I had in hand, did not. I prefer, use, and recommend the Goodridge. They cost a little more, but fit perfectly.
Shotokan1509
CT
Ok dumb one, what is the brake fluid capacity? Want to go ATE, not finding local.. need to order the flush + bit extra for bleed waste but don't want 14 gallons sitting around.
Gray Ghost GT
Madison, AL
1 liter (container) should be sufficient, but I always buy a 2nd one for bleeding the brakes at the track.
