s8v4o
- Joined
- May 18, 2007
- Posts
- 3,476
- Reaction score
- 10
You won't be able to use the 2 step and spray because that requires you to activate the TPS switch. The results of that will be some really loud explosions in the exhaust and potentially a backfire.
So I shouldn't be having any problems using the wotbox with a built in window switch right? Theory is as long as the clucth is pushed in while at full throttle the nitrous kit shouldn't be activated until I release the clutch. So basically I will be two stepping off the line then as soon as I release the clutch, the two step should stop and the nitrous should kick in. This also should mean that during the no lift shifting the nitrous should also turn off during my shifting.
Anybody using the wotbox with built in window switch?
- I have a traditional "wrap" style heater coming in the mail this week
