Road Race Suspension///
lakeside
BMR Custom K-member
BMR Tubular Adj Front LCA
Ground Control Coil-Over Struts
Ground Control Camber Plates
Koni Front & Rear
Eibach Springs Front & Rear
Ford Racing Sway Bars
BMR Upper and Lower Rear Control Arms (Heim Joint)
Steeda Adj Tie rod ends
BMR Adj Panhard Bar
DusterRT
Defected to Deutsche
Seattle, the Sunshine City
FR500GT
Orange County, CA
ross murry k-member with changed pickup points
fr500c control arms
steeda race upper3rd link
steeda front bar
rear bar none or v6
steeda race pan hard bar
steeda rod lower control arms
steed relocation brackets
hypercoil springs
full coilover moton 3 way adjustables
ground control full race caster camber plates .
I hate you Steve!
STEVE_POE
coyote powered fr500s
Cincinnati
I hate you Steve!
you would hate me even more if you knew what I gave for them.
They where removed from Patrick Demseys old grand am gs car back in the day .
could probably triple my money if I got is autograph on them "lol"
Thinkkker
Spring, TX
AST4200 coil-overs, AST 4100 shocks
Vorshlag Gen II C&C Plates
Vorshlag adjustable rear spring perches
Hypercoil springs 6" 900# front, 7" 350 rear
Steeda Adjustable front Bar
Stock rear bar *need adjustable/smaller*
Enkei NTO3+ 18" X 10.5" 30mm offset all around
Hoosier A6 295/30/18
More stuff in the works......
jsnyng
Alpharetta, GA
Koni Sport Shocks/Struts
Steeda Sport Springs
Steeda HD Strut Mounts
Strano Adjustable Front/Rear Sway Bars
Fays2 Watts Link
BBR Billet LCA's
Ch4r1ie
The Limey Bastard
Down Under
PM'd you a couple of questions about these :thumb2:
ArizonaGT
Road Course Member
Phoenix, AZ
Eibach Pro Kit Springs/Swaybars/Bushings
Koni Yellows
J&M Camber Plates
J&M Anti-Squat Brackets
Roush Track Pak wheels
275/40/18 NT01s
Sitting in the garage for future install to other vehicle:
Roush Track Pak kit
J&M adjustable UCA
And just for a refresher:
FR500GT
Orange County, CA
I read up on your car last night:
http://www.sccaforums.com/forums/forumid/103/threadid/47484/scope/posts
Lots of good info on the AST coilovers as well as test fitting a lot of wheels!
FordFan
Eaton Truetrac with 3.73's
Griggs ST rear
Shelby GT front w/camber plates
Rear sway bar delete
Brembo GT500 brakes w/hawk HP+
Steeda ultra lites with BFG R1's
Steeda G-trac brace
Dreadknought
HOON MONSTER
Texas Hill Country
Suspension Techniques ST Coilovers
MM Caster Camber Plates
Steeda Bumpsteer Kit
Steeda X5 Balljoints
Strano adjustable swaybars front and rear
BBR Billet lower control arms
Fays2 Watts link
ATE slotted rotors
Hawk HPS pads
Nitto NT05 255/35R20 front 275/40R20 rear
kevinatfms
EX-ford tech(6 years)
MD
~gt500 wheels w/ 275/40r18 sumitomos(street)
~gt500 wheels w/ 275/35r18 r1's(race)
~frpp k springs
~frpp adjustable drop links
~frpp f&r sways
~KR dampers w/ gt500 strut mounts
~steeda bumpsteer kit
~steeda rad support
~bmr k member
~gt500 front lca's with x5 bj's/front poly bushings/rear inserts(steeda& energy suspension)
~umi rear lower control arms
~edelbrock rear uca w/ rod ends
~umi rear uca mount
~umi panhard rod and brace
~umi lca relocation brackets on lowest hole
~umi subframe connectors
~CHE driveshaft loop
~baer gt plus big brake kit w/ SS lines f&r
my setup has changed, new setup is:
tokico blues all around
baer calipers replaced with stocker corvette c5 calipers(PBR aluminum)
carbotech xp8 pads all 4 corners
jsnyng
Alpharetta, GA
Fays2 Watts Link
BBR Billet LCA's
My setup has changed as well.
KW V3 Coilovers
MM Caster/Camber Plates
Fays2 Watts Link
OEM LCA's
Ferodo DS2500 Pads - Front
Hawk HPS Pads - Rear
Norm Peterson
corner barstool sitter
RIP - You will be missed
Nothing all that serious yet . . .
Koni yellows
Steeda upper strut mounts
Sam's 35mm & 22mm adjustable sta-bars
Strano/UMI adjustable endlinks
18x9.5 GT500 wheels
255/45-18 Goodyear Asymmetrics
Hawk HPS pads
ATE rotors
The same slightly out of spec alignment that the car originally came with
RedMosesSC
NYC
- Saleen Watts Link
- Saleen S281 springs
- Saleen S281 Socks/Struts
- Steeda Front and Rear sway bars (Billet mounts)
- Steeda Adj Upper Control Arm and Solid Lowers
- Pirelli P Zero Rosso 245/275-40-20 on 8.5"/10.5" XXR wheels (agressive offset)
- CHE K-member brace w Torque links
- Saleen/Stop Tech 4 piston 14" front brakes
jayel579
North Jersey
Koni yellows
18x9.5 GT500 wheels
Hawk HPS pads
ATE rotors
ESP Norm! Bring that thing out! lol
I am still working on my upgardes, I will post once I get my credit card statement
NEMustang
Mad Motorsports Products
North Reading, MA
2007 GT/CS
ALL Around:
- Enkei PF01 18x10.5 38mm
- Hoosier 275/35/18 R6
FRONT:
- Brembo GT500 4 Piston
- DBA 5000 14" 2-Piece Rotors
- Hawk DTC-60
- FRPP Brake Cooling Kit
- Agent 47 Brake Cooling Scoops
- Steeda Radiator/ARB Support
- BMR K-Member
- BMR Rod/Delrin Lower Front Control Arm w/Tall Ball Joint
- BMR Adjustable Front ARB
- BMR Strut Tower Brace
- UPR Bump Steer
- Ground Control Struts w/coil-over conversion - Lowered 2"
- Ground Control Custom Valved Koni
- Eibach 440# springs
- Ground Control Caster/Camber Plates at ~-2.85 Camber for track
REAR:
- Ground Control Height Adjusters - Lowered 2"
- Groung Control Custom Valved Koni Sports
- Eibach 220# Rear Springs
- BMR on-car Adjustable Upper Control Arm - Poly
- BMR on-car Adjustable Lower Control Arm - Rod End/Poly
- BMR on-car Adjustable Panhard Bar, Brace and Panhard Relocation
- Steeda 13" Brake Kit with DBA 4000 13" One-Piece Rotors
- Hawk DTC-70s or HT-10
Other:
- FRPP Cold Air & Tune
- Flowmaster 3" American Thunder
- Sparco Evo 2 Racing Seats
- G-Force Pro 6-point
- Sparco Harness Bar
- Hurst Short Throw Shifter
- GoPro HD Hero
- TrackMaster GPS Data Aquisition
LS1EATINPONY
The Banker
Wheels:
Enkei RPF1 18x9.5 +45mm
Suspension:
Eibach Multi Pro R-2 coilovers
Metco adjustable UCA
J&M LCA's
Maximum Motorsports CC plates
Steeda adj panhard bar
This is what ive managed so far. I'll be getting more this summer when I graduate and hopefully get a job
