New Part From Steeda - X11 Ball Joints
S
Steedagus
Guest
Starting with the 2010 GT500 and then all 2011 models, Ford changed the ball joint specification which prevented fitment of our previous X5 ball joint kit.
After a long design and testing period we have finally released the X11 ball joint which fits 2010 GT500, all 2011 and 2012 Mustang models.
Like our previous ball joints, the X11 design is a longer ball joint which on lowered cars raises the front roll center improving front steering response and overall front cornering grip.
When using the ball joint which relocates the outer control arm pivot point, a bump steer kit must be used with it because the relocation changes the geometry between the control arm and the tie rod ends which increases bump steer. The bump steer kit allows you to correct this.
Check out the new X11 ball joints here: http://www.steeda.com/store/2011-up-mustang-ball-joints.html
Check out our 2005-2011 bump steer kit here: http://www.steeda.com/store/steeda-bumpsteer-kit-for-ford-mustang.html
DusterRT
Defected to Deutsche
Seattle, the Sunshine City
How does it differ from the earlier ones? Is it larger/stronger/etc or just 'different' in that it needed to be redesigned to fit the new A-arms?
waketek516
Pedal to the Metal!
Costa Mesa, CA
You see the first sentence?:thud:
"Ford changed the ball joint specification which prevented fitment of our previous X5 ball joint kit. "
S
Steedagus
Guest
Exactly this, its different and needed to be redesigned to fit the new models. I believe Ford did make the 2011 version slightly stronger as well, ours exceeds even those specifications.
DusterRT
So just to be 100% clear, is it the same X5 ball joint with a redesigned housing, or is the X11 going to be a little more robust than the X5 is? As in, would there be an advantage to upgrading to the new A-arms and using the X11 vs. the old A-arms and the X5?
DRock
Im going to BUMP this cause im about to do this mod and would like to know if it is worth it switching over.
S
Steedagus
Guest
The X11 is a clean sheet design. Both the X5 and the X11 are stronger than stock. Out of the 2 I believe the X11 has a slightly higher tensile strength, but either one exceeds stock strength specifications.
