Does Water Wetter improve intercooler efectiveness?
Kobie
I know it helps engine coolant temps, but will it help the intercooler?
dysan
Dis-Member
Williamstown, N.J.
Before I installed my trunk intercooler tank I put some water wetter in the small edelbrock reservoir and if I remember correctly it lowered my IAT's about 10 degrees.
Mikes_BLK_GT
Mid-Life Crisis
Pacific NW
I only used half a bottle in the intercooler, I have heard if you put in the whole bottle it will foam up
94tbird
4R70W FTMFW
True statement.
Not true. Depends on how much fluid you have in your system. I had a 6 gallon tank and ive put 1.5 bottles in before.
I don't add any anymore because its a waste of money if you use ice in your Intercooler tank. Every time you drain the fluid to add more ice, your draining the water wetter too.
Kobie
So about a half bottle of water wetter is good, but switching to something like engine ice might be better overall?
dysan
Dis-Member
Williamstown, N.J.
Engine ice? I think you're getting confused. 94Tbird, myself and others have large intercooler tanks that when we're at the track we have packed with water and ice, we're not talking about a chemical additive but the real thing.
chuck@evoperform
Boss surgeon
Official Vendor
Delaware
Yes, water wetter works. It is essentially a surfactant that reduces the surface tension of water, essentially making the water "wetter". I've always wondered if you could potentially use a soap or detergent to the same effect when racing, so as to not waste bottle after bottle of the wetter.
69Mach1-409
South Jersey
Yes it works.
I added a full bottle to the coolant system & another bottle to the intercool system when I put the Whipple on.
94tbird
4R70W FTMFW
exactly!
Kobie
I assumed the intercooler tank was filled with coolant. If so engine ice (the chemical) should work. I guess I better check my tank to see what's in there!!
Are you only supposed to run watter in an intercooler?
94tbird
4R70W FTMFW
I think your still missing the point.
In its stock form, the Intercooler tank is filled with coolant. its not a 50/50 mix like you have in your car's radiator, but a 70(water)/30(antifreeze) mix. You can add water wetter to that just fine.
Some of us have removed the stock tanks and installed larger tanks that hold anywhere from 2 gallons to 6 gallons of fluid. This increases cooling as there is more fluid, but when at the track, also allows us to drain the coolant, and add physical ice cubes to the tank to super cool the remaining fluid. IF we were to put water wetter in that, after our track pass when we drain the melted water, the water wetter would go with it and it would become a gigantic waste of money for us.
dmhines
KONA GT
Cumming, GA
I went by the instructions when I installed my Saleen S/C ....
"SALEEN SERIES VI SUPERCHARGER FOR 2005-07 MUSTANG
[FONT=Times New Roman,Times New Roman PSMT][FONT=Times New Roman,Times New Roman PSMT]MAINTENANCE SCHEDULE
[/FONT]
[/FONT]The supercharger kit comes complete with an independent coolant system. Regularly check the fluid level of the intercooler system. The fluid should reach the bottom of the neck of the recovery tank when the system is cold. With the water pump on (key on or car on), check as often as every couple of oil changes that the fluid is circulating. If it is not, purge the system per the instructions in the supercharger installation manual.
Change the fluid in the intercooler system as often as the radiator fluid is changed, using a 50/50 mix of antifreeze and water.
If you have any questions, please call Saleen at 800-888-8945."
94tbird
4R70W FTMFW
[/FONT]
I think you also missed the point of the OP's thread lol. its not about what fluid to put in there, or what mixture, its about how water wetter will work/affect things. I was merely pointing out if he had a larger than stock tank, or used ice, it wouldnt be cost effective.
dmhines
KONA GT
Cumming, GA
I understand what the OP is asking .. I was just commenting on your reply indicating the coolant ratio is 70/30 not 50/50 ...
scramblr
New Braunfels, Texas
O.K., true if using the piss ant Saleen tank which I can overflow with a piss. :)
94tbird
4R70W FTMFW
Most recommend 70/30 for max cooling as water cools better than antifreeze, but if your cold weather driving 50/50 is what you want so there isnt a freezing issue. If you want MAX MAX cooling, drain it all and run distilled water.
