How to obtain Oasis Code to Reprogram a PCM!
soyomakate
I am trying to bring back to life a bad pcm from a 07 mustang GT but since this thing is dead the ford ids needs the original Oasis code for it to know how it left the factory floor and reprogram the PCM.
so..how/where do i get that code?
KenB
If you don't have any luck, I can bench flash PCMs and fix it for you with no additional info needed.
lito
Caracas, Venezuela
I don't remember ever needing an oasis code and I have done weird stuff with the IDS.
If I recall correctly you had access to another car, by any super lucky chance, do they share the same calibration so you could flash the new one as a replacement? (then once in the other car you can redo PATS, VIN and VID block stuff.
