Burnout F/I
scramblr
New Braunfels, Texas
K., simple one for you guys. While N/A at the track I'd do my burnouts in 2nd based on previous recommendations.
Now that I'm FI, do I do it the same way or start in 1st and then shift to 2nd? TIA...
I drop the clutch in 2nd. I did it this way with 3.55s and 4.10s - works great
TexasKyle
D.I.L.L.I.G.A.F
Katy, Tx
I do mine in 2nd (but with an auto trans).
Thanks for chiming in Don. I was wondering about this for an auto car. Before you had FI, did you do it the same way? A S/C is in my future, but I wanted to start hitting the 1/8mile track thats around here on my stock setup first.
gmantheman
Escondido, CA
I have done my short burnouts on street radials in 1st. I am curious, is it better to do burnouts in 2nd with a manual?
don_w
Dyno Numbers - Who Cares?
San Diego, CA
It really has nothing to do with N/A vs FI. It's about wheel speed, so it's more dependent on the rear gear ratio, tire size and rpm.
I like to have the rear tires spinning at about 45-55mph during the burnout, and at between 5500-6000rpm. When I was running 3.31 gears, I did burnouts in 1st gear at 6000rpm (with a 28" tire). After going to 4.10s, I changed to 2nd gear and try to hold the rpms between 5500-6000.
marcspaz
~Resigned~
Here is a video from my last trip to the track. I have a stick with 4.10's and seasonal radials. I'll burn in 2nd at about 5500 rpms until I see nothing but smoke out the back window...hahahhaha. It helps better than short or no burn-out. Check it out.
http://youtube.com/watch?v=vCyMuKasHNk
TexasKyle
D.I.L.L.I.G.A.F
Katy, Tx
Thanks again Don. I'm gonna have to head out to one of the country roads west of town and do some practice runs before I head to the track. On a side note, I got to drive Liz's Saleen powered Stang recently and have since advanced my timeframe for getting my own S/C.
:clap: That was a hoot. I went from thinking about doing it sometime this year, to NEEDING to do it this summer. haha.
don_w
San Diego, CA
Every car, track and tire combination will require a different type of burnout. DRs usually need more than slicks (and hence don't last as long). With my slicks, I wait until I see smoke in the driver's side mirror and then drive out of it about 2 seconds later.
Practice is fun!!
Every guy deserves to get blown...
ChevyKiller
Preferred Internet Drink
Honestly, your burnout should really be determined by the tires on the car.
For example, the MT ET Streets actually work better with a short (but fast) burnout. The radials require a little more time at speed.
Regardless, the one constant is you want to be at about 55-60 mph during your burnout.
scramblr
Cool, thanks for the info guys. In second (on MT ET Streets) I was maintaining 55-60mph but I had read through the threads about starting in 1st and shifting to 2nd. The rear end doesn't like that much as it starts walking to the left after I shift. Starting off and finishing in 2nd the rear stays planted.
