Installing an Eaton Posi this weekend - questions
jsnyng
Alpharetta, GA
Are there any gotchas or tips/tricks I should know about installing one of these? I'm also putting on the SVTPP FRPP finned diff cover. How much gear oil should I get? I'm thinking of going Royal Purple this time around. Any help will be appreciated.
chuck@evoperform
Boss surgeon
Official Vendor
Delaware
3 quarts is sufficient. Fill til it comes out the fill hole in the front side of the housing (drivers side).
jsnyng
Alpharetta, GA
Thanks Chuck. That's about what I was guessing. I'm really hoping the Eaton will let me put more power to the ground on the autocross course. Inside wheel spin is a bitch on the OEM LSD. Any installation gotchas, or is it pretty straightforward if I've done gears before?
KJGT
East, TN
Just swap it out and check the ring gear backlash, unlike just a gear swap you have to make sure there is enough (or not too much) preload on the side bearings. Make sure you have some shims laying around.
Scott_0
OxFORD, Pa
I believe the Eaton requires a bottle of friction modifier in addition to the gear oil, atleast when I installed one in my Fox Saleen years ago,and if Im not mistaken they recommend you use non synthetic
ArizonaGT
Road Course Member
Phoenix, AZ
JASON PLEASE READ THE MANUFACTURER'S RECOMMENDATIONS LISTED ON THE BLUE (?) CARD INSIDE THE BOX!!! It is very specific about what gear oils they want you to use.
Recommended capacity from Ford is 1.7L (3.15 pints)
Additionally, Ford's fill level check is to fill to roughly 1" BELOW the fill hole, with the car level and the axle at ride height. Check out the 05-09 manual page 205-02B-1. You can check the fill level easily by putting a 90* bend into a lightly-colored zip-tie at or just past the required length and then using it as a dipstick of sorts.
jsnyng
Alpharetta, GA
Thanks man. I haven't even opened the Eaton box that you sent me, so I haven't seen that blue card.
I have a very skilled mechanic who is going to do the install, but he really likes for me to show up with all of the parts/fluids I need when I get there. I will open the box this evening and read that. The Eaton website had very generic instructions, "Remove lubricant fill plug and install recommended volume and type of rear axle gear lubricant and limited slip differential additive. Re-install and securely tighten fill plug."
Intervention
I believe they recommend ONLY a 80-90w Dino oil...
Say synthetics dont offer enough shear protection or something. Sorry its been a while since I seen the card
Scott_0
OxFORD, Pa
sounds right, when I had my Eaton installed about 6yrs ago they recommended dino oil and a bottle of friction modifier, but I wasnt sure what if anything had changed
