bigwilly43729
I do stupid shit, a lot
I know this might open up a can of worms, but I am curious. How did this guy get up to 875 on pump and the other guy blew his up at much less than that?
How much boost and how many deg of timing ?custom built 5.0L stroker (ceramic coated diamond pistons, eagle crank, billet rods)
ported heads
65lb injectors (too small)
custom fuel system (return style)
stage 3 comp blower cams
GT500 6spd
Spec stage V clutch
every BMR part avail lol
What 'other' guy?![]()
????? Also when does the meth spray on this car ?How much boost and how many deg of timing ?
Was this with the 127650 cams ?22lbs of boost. 21 deg of timing
Ahh , F1C and a std trans .... 22psi and 21deg is alot on pump, isnt it ? Or is that the meth working ? What would this car be at without the meth ? See my sig and you will understand my 1000 questions. LOL! You are at the same timing and boost that I made 713 on , so i am very interested .we are going to change the meth kit around a little to utilize a injector instead. when we do that we will go up 4-5 more lbs of boost and hopefully break the 950rwhp range. This is a F1-C and its out of boost haha, we are really impressed with the power and its likely one of, if not the highest hp 3v street car out thereThe car will goto the track in the spring in hopes of some decent mph, it will never ET well unless he puts a auto in it.
