05 sonic blue gt500 ??? Look inside !!! Price Reduced
Just like it says.. I have a 2005 sonic blue GT That i spent the time and $ doing a GT500 drivetrain conversion. Everything was done as a FACTORY car is built. Every wire harness was purchased from Ford and the car was completely stripped inside and out to make this work as a factory car. the. When you hook up to the Ford IDS diag computer it comes up as a 2005 GT500. AGAIN NOT 1 WIRE WAS SPLICED ALL HARNESS WERE REPALCED WITH NEW INCLUDING THE DOOR HARNESS. here is the list.
brand new 2007 Crate Motor complete with all componets.
kooks 1 7/8 lonk tube headers
off road 3in x pipe
steeda cold air intake
2.6 upper pully
magnaflow mufflers ( not the magna pack ) quite while diving LOUD when WOT
used TR6060
crate motor came complete with clutch
old style but if you dont slip it it will not heat up and chatter.
TRI AX shifter
full BMR K member
BMR A Arms
Tokino Adjustiable struts and shocks
Brand New Currie 9in rear with 3:50 gears 31 splin axels and True Track limmited slip.
FUll BMR upper and lower control arms in the rear with pan hard bar
solid drive shaft for the 9in rear
Bear 6 piston front caliper and rotors, ran out off $ for the rear so the rear brakes are stock
Steeda ultra light 20in wheels with TPMS sensors that all work
The Entire INTEIOR IS BRAND NEW came out off a 2008 that was crashed
it has the Factory Ambionce Lighting package, shaker 1000 , side air bags
seat belt extenders that hold the belt closer for you to reach behind. the cluster is brand new with the MY color option
Factory HID headlights
Steeda hood and CDC chin spoiler
I work for a ford dealer and it took me 4 months to do this build, I programed the PCM with an 09 brand new computer and as built factory data, the vehicle data comes up with my VIN as 2005 and i Programed The cluster as a 2008 so EVERYTHING WORKS!!!
i had the engine bay redone at my body shop to match the outside clearcoat.
went to the track once and got 2 passes on a drag radial
car went 11.6 @ 119mph cut a 1.5 60 foot and i left at idle, granny shifted and went through the traps before i got into 4th gear. i have a brand new set off 4:11 gears that go with the car.
its running on a evo perf tune that FRED made and has a check engine light for bank 1 and 2 drivability lean. both the long trims are at 25% while driving normal which is why it cuts the light. never dyno tuned!! There is also an abs light on for the right rear sensor that i have not got around to doing yet.
The rear makes noise heel and toe because my Asshole Brother let the 3rd member fall off the work bench and it landed on the pinion bearing. Currie has the install kit for $110 so i havent had time to do the gears and repalce the bearings yet, car runs and drives perfect gets a ton off attention because of the body. I hate to sell it but i need the cash so it has to go. who ever gets it will not be dissapointed.. always garage keept never seen rain or smoked in. I put almost 1,500 miles on the entire setup. any questions feel free to call me @ 845-522-3613
Make Offer
Uploaded with ImageShack.us
off road 3in x pipe
2.6 upper pully
used TR6060
TRI AX shifter
full BMR K member
BMR A Arms
Make Offer
