'07 GT500 hard to shift 4th to 5th
kazman59
King of Kazmania
Kazmania
MGW gen2, Blowfish bracket, Mobile 1 fluid. Installed for almost 2 years, just last month or so been getting progressively harder to shift from 4th to 5th, today it was so hard I just started going 4th to 6th with no problem. Car's driven almost every weekend, all other shifts are fine. ~60k mi.
Anybody?
DieHarder
Anybody?
synchro’s?
Midlife Crises
Fairbanks, Alaska
When you say “hard too get into 5th” do you mean it pushes normally out of 4th and 5th is blocked. Takes a lot of pressure to go in? Grinding?
kazman59
King of Kazmania
Kazmania
Comes out of 4th easy, I have to deliberately push up, over and up with considerable force. Almost like its locked out. I noticed at low speeds (25-35) it's much easier. Of course, at low speeds I'm not going to use 5th just testing.
kazman59
King of Kazmania
Kazmania
Yeah, that's what I didn't really want to hear. I was hoping for some shifter adjustment advice or such.
Minot, ME
All bets are on, just seem to favor the shifter is out of alignment. Working or not is a very fine line there (or used to be). If all other shifts are OK, must be releasing clutch sat. if only trouble in 4th to 5th? That would be the furthest push up and far right, I’d just take a look, absolutely nothing to lose before dropping tranny. Can picture that right fork (bolts loosened) as gotten a bit wobbly if looks similar?
Too as I can recall the Ford OEM version (BOSS and MT-82 anyways) shifter would have rubber bushings that could flex eventually and Blowfish bracket was answer to that? F30AEBAD-1FF0-4E2C-9C59-A6F904A0795B.png
Assuming its not a shifter issue:
First sign of clutch going out. If syncros were shot, you would get a grind and not a lockout. And it will be a grind if my suspicion is correct and you keep forcing it into gear.
How is it going into reverse?
As the clutch wears, pedal force starts to increas. Because of this, the clutch does not fully release. If the rpms do not match, the syncro blocks the shift. This drastically accelarates syncro wear.
Midlife Crises
Fairbanks, Alaska
This is absolutely true.
Macman45
Resident Geriatric
Atlanta / Bay Area
This. Do the 6th gear parking brake test where you try and let the clutch out to watch it die. With those miles and age I bet its clutch time
kazman59
King of Kazmania
Kazmania
I believe the clutch has been changed out. I've driven a stock clutched 08 GT500 (Lee's) and my clutch is considerably more stiff. And Lee has driven mine and remarked how more effort was required than from his.
One of these days I'll get it up on the stands and check the shifter, until then it'll be 4th to 6th.
gbstang
Not the Clutch.. I am going with the Shifter assy. probably a bad bushing since its only happening at the 5th throw... , I have the MGW--it is awesome...
kazman59
King of Kazmania
Kazmania
Seems to do it more the hotter the drivetrain gets. It'll start out fine then further into the drive the tougher it gets. Also the shift to reverse gets tough also.
The lockout perhaps?
golkhl
Las Vegas, NV
When was the last time you changed your transmission fluid? Could also be your hydraulic slave and or clutch master cylinder starting to go…..
kazman59
King of Kazmania
Kazmania
Fluid changed to Mobile1 May of '21. I prolly should call MGW with a few Qs...
There is no lockout (syncro) on reverse.
Your clutch is on its way out and needs to be serviced.
No majic fluid change will help this.
And every drive you take beats the crap out of your transmission's syncronizers.
FBO500
Omaha, NE
Hey, sorry for the year old bump but did you ever get this figured out? I also have an 07-09 GT500 with an MGW shifter, Spec clutch, N2MB wotbox and Amsoil transmission fluid.
I’m having a similar issue with shifting from 1st to 2nd and 2nd to 3rd. I cannot shift at WOT without hitting a wall or shifting considerably slower. Was it an issue with your shifter being out of alignment?
Mods please delete if this bump is against forum rules. I can start a separate thread if necessary. Thanks
Edit: Forgot to mention, I’ve also noticed that shifting degrades as the car gets hotter/driven as well. It seems like I can turn the car, let it idle and then make a couple hits with decent (not great) shifts and then once the trans gets hot I start having issues.
kazman59
King of Kazmania
Kazmania
I put the MGW short shaft back on and found I going to far to the right when gong to 5th or reverse for that matter. Like I was try to hard, pushing past the 'gate' so to speak.
Still not what I consider perfect, perhaps syncros, but good enough till I win the lottery.
