rcm90
I don't mind so much losing some around town, but wonder if went with a less aggressive convertor then yours I can keep the hwy just lose in the city if that is possible?
Does the convertor do anything on the car while it is in motion or is it just from a stand still?
On the highway the stock and aftermarket converter should be commanded lockup with zero slip. This is why mpg will not be altered. The drivability/mpg around town depends on the trans tune in the car. The tune could command the converter stay unlocked until 50mph regardless on load, resulting in a large drop of mpg. Where my car is commanded to lock in 2nd with a pretty high load percent. So over 20mph the converter is locked through the 2-3, 3-4, 4-5 and 5-6 shifts resulting in better mpg around town due to the lower rpm and it feels more like a stick car than a stalled automatic unless I give over half throttle.
I've had the car both ways and with the converter locked down low while being on e85 im only down 1-2mpg vs it being unlocked and on regular gas.
