Watch Amazon's deals. A lot of the time they have really good tools on sale. I have gotten every ratcheting wrench on there and all Gear Wrench brand.
Id say no, it does not include a maf.Are these eBay cold air kits worth messing with? Priced much better than the BBK offerings....
https://www.ebay.com/itm/BCP-BLACK-94-95-Ford-Mustang-5-0L-V8-Cold-Air-Intake-Racing-System-Filter/141831909287?fits=Year:1994|Model:Mustang|Submodel:GT&hash=item2105d72fa7:g:ncAAAOSwZ41eYV8L
I did have a question with regards to the vacuum lines - most of the videos I watched had two solenoids that were removed (these were on Foxes on the passenger side fender). Do the 94-95 not have these? I've just got the two from the check valves capped and wrapped up, but I'd like to get the lines removed to clean things up further. I didn't see any on the fender unless I was overlooking them.
I ordered an EGR fooler plug and plate from eBay. Planning on deleting those when the parts get here.
Nevermind, i was thinking that the maf was built in to the air filter housing. They did that on the 4.6's. So yes that cai you posted should work.
They have the same airbox, at least my 99 gt did.The maf wasn’t built into the factory airbox on the 4.6 either. I think the 3.8 might have been set up like that though.
Why remove egr? Has zero impact on power, may make the car ping, and loss of MPGs.
Just curious. Egr works off vacuum. WOT - no vacuum - no egr.
The smog pump/EGR solenoids and vacuum lines are hidden behind the fender liner underneath the passenger side front fender. If you pull the fender liner out you'll have good access to remove all of that crap.
Just wanted to let you know of potential side effects of EGR blockoff. Sure it looks better deleted, but it has benefits having it.I was under the impression that anything emissions-related could be tossed. Plus it would clean up the under-hood area a bit more. It's a freaking rat nest under there as it is.
