RedRoush3v
My 2005 mustang gt is running into some issue with what i believe to be the smart junction box. It started with the right rear tail light and front driver headlight acting up and not displaying full brightness and turn signal not working so I attempted to clean it and after that the OBD-2, and gauge cluster stopped working as well. The gauge only displays a dim airbag light at all times no speedometer or rpms or fuel or anything and the OBD doesn't give any reading or signal. I bought a part numbers matching SJB from Ebay and plugged that into the car but experienced the exact same issues/symptoms. I'm thinking the issue lies in the connectors themselves and was curious if anybody experienced this before or knows which connector would control those junctions. I also wasn't sure if a reprogramming would be necessary to even get these functions back if it was the SJB itself. I also checked all the fuses from both fuse boxes and relays and if It were to be the connectors would it be as simple as cutting the harness and splicing a new connector in its place from a parts matching SJB car? Car turns on but I need to retune it and can't without OBD functions. Let me know what you think, thanks.
