2010 mustang e force alternator
detn8tor
Beaufort SC
When the kit changes the alternator spin direction does the alternator still work? any one have this problem? Fan spin the wrong direction heat up and blow up the alternator?
BruceH
BBB Big Bore Boss 322
Are you having a problem with yours? That's the kind of thing that would of showed itself by now. BTW the Saleen kits also flip the alternator. The same guy designed both kits.
skwerl
tree hugger
central Florida
The 2010 alternator is different than the one Ford used on the 05-09. It's a Denso and has a clutched pulley, so installing it to spin backwards isn't going to work. You need to swap the pulley (if you can find one to fit) or pick up an older style alternator.
BruceH
The kit should come with a standard pulley and the tool to pull the clutched pulley.
detn8tor
Beaufort SC
skwerl,
Will a 09 work on a 2010? mount the same? Plugs the same? i see there both rated at 135 amps....Just curious if they are interchangeable....
Brett
BruceH
All of the 4.6 3v Mustangs have clutched pulleys. If you swap the alternator you will still have to swap the pulley.
detn8tor
Beaufort SC
Kit comes with a pulley (7 rib) that goes on the alternator.....My problem is when i flipped it, mounts in backwards, started the car on intial start up my battery light came on and smoked the alt...Mechman alternators told me that the fan inside the alternator is whats wrong getting too hot and frying the voltage regulator....
skwerl
tree hugger
central Florida
Ask gmitch, he knows about these alternators. Most aren't aware that Ford used a different alternator the last year or two of the 4.6 3v. My 09 Bullitt had the newer style alternator and when I went to an 8 rib kit the alternator pulley wouldn't fit and the company selling the pulley kits was unaware of the difference.
detn8tor
Beaufort SC
Bruce,
I know the universe spins in one direction do you think it could've possible just been its time to go? At the time of install? On initial start up?
Brett
BruceH
It happens. I've never been a fan of the backwards alternator kits.
Bruce,
Brett
HG6283
Granny Shifter
Shrewsbury, PA
More than 50,000 miles on my E-Force with the backwards alternator with no problems.
The pulley was changed to the one in the Kit, with no clutch. The pulley in the kit was clearanced because of a feature of the front engine cover.
skwerl
tree hugger
central Florida
If the pulley in the kit was designed for the 05-09 alternators and it fit, then you don't have the new Denso alternator.
HG6283
Granny Shifter
Shrewsbury, PA
I don't know what manufacturer the alternator is.
It's the one that came on the 2009 Bullitt I have.
Here is the section of the E-Force installation manual:
skwerl
tree hugger
central Florida
Yup, that's not the same alternator as what was asked about. The 2010 (and some 2009) is different.
detn8tor
Beaufort SC
See what i am talking about? WTH!?!?!?! I'm about to trade it in for a Vette!!
Or get really stupid and a porsche!!!
