2011-2012 Axleback flange tab?
PvilleStang
Your tax dollars at work!
Pflugerville, TX
Hey, sadly, it was a trick I picked up with the Roush instructions along with the User reviews on CJ Pony Parts AND American Muscle.
aequitas4
Baton Rouge LA
as said, you can use a angle grinder with a cut off wheel, a Dremel with a cut off wheel, tin snips, or if you have none of the above available to you, you can bend the clamp back and forth until the small piece of metal breaks
I did the "bend back and forth" method and it worked great.
keoni1984
Homicidal
Jacksboro, TN
Also, when you're swapping the exhaust, it helps to:
Remove the exhaust hanger retention bolts on the forward hangers.
Loosen the clamps near the H on the pipes.
These will help tremendously with removal / installation.
+1 I did this as well, much easier. I basically took the AB's, hangers and mounts off all as one unit... tight fit, but if you fanagle it, it'll come out without having to loosen the rest of the exhaust connections. BTW, the Roush AB's sound amazing, cost ~$450, AND come with clamps. Just sayin ;)
bruthru2003
Congrats on the axle backs. How did the install turn out? I have the Borla Ataks on mine and I love them.
MUSTANG GUY
I wasn't able to install it because we got some extreme cold and about 6 inches of snow and even tho my cars stored in a semi heated garage I plan on doing the rear diffuser at the same time and with it being so cold I was worried that the tabs will be brittle on the diffuser and higher chance of breaking.
It's better today and should only be just under the freezing mark this weekend, so I will be doing both this weekend. I'll update when done
ModTechRacing
I did the same that everyone else is saying just bent it back and forth till it broke . then put it in a vice just tight enough to hold it, and I ripped the tab off the clamp
2012BlkBrem
I swapped them out for a set of muffler deletes ... Did in driveway without removing swaybars, or anything besides the stock pieces.. other owner told me might have to remove them but he must've been high.. a little liquid soap on the rubber muffler brackets goes miles for getting them to slip off... SOUND is AMAZING and half the price of Borla or the like
Miked73USA
It's easy, pull old mufflers and clamps off, in one piece. Put new mufflers with new clamps on. Depending on your axle backs you may need to drop the rear swaybar and panhard bar brace. I did when I put the corsas on. It took me about 30 minutes to do both sides on ramps.
How do you like them corsas? Which model did u go with? And did you connect them to a offload pipe? Any drone? Any vid of them? Thanks, and have a good one.
