Jinx
Photography Blogger
Here is the post I put on HIDPlanet:
This is my first post on these forums. I've been reading for a long time and just recently registered on here.
After seeing everyone"s projects, I've finally got an idea in my head that I like to do for my car. I think the idea is straight forward.
It's basically a 2013-like taillight setup in a 2005-09 stock housing. Here is the 2013 mustang taillight design and function:
http://www.youtube.com/watch?v=42c-TtokFc4
It has sequentials, but has functional halo rings to accent it. The outer halos stay lit the whole time I think when the headlights turn on (or all the time if DRLs), the centers led cluster inside the halo rings only light up under braking and turning (sequencing effect).
Mustang guys have sequential splice in harnesses available for PnP LED tower replacements and regular bulbs too. However I'm not sure how to wire it (resistors and etc) to make it function with those harnesses. I figure the halo could be wired into the headlight switch I dunno. Basically it seems that I should have normal brake light and turn functions (on and off) and no halo with headlights off. Then the same as when headlight on except just the halos turn on. I'm lost, but I really like to get into this.
I'm thinking 6 boards (with a few rows of standard LEDS) and 6 shaped boards in the shape of square rings (aac style SMD LEDS setup).
Here is a photoshop mockup I made:
They are being very helpful and I'm going to try to do a DIY and post up wiring diagrams once I and some of the guys helping me come up with one.
Opinions?
BTW, using stock housing and len. No aftermarket crap. This is going to be a true LED retrofit.
Opinions?
