2013 squeaky front suspension
sd_fox_racer
picked it up end of june, got 1,700 miles on it and i noticed when ever i go over speed bumps the front passenger squeaks loud, almost as if they forgot to grease something there. anyone else having this problem? suspension is stock.
grabber197
stanford KY
My 13 is quite as a mouse.
Xorak
Memphis, TN
i just had my 2012 fixed for this. there's a TSB for it that covers 2011-2013 Mustangs. they have to replace the front lower control arm(s).
TheWizard
Katy, Tx
Well mine's at 32k and has been back twice. It's been squeaking since 12k miles. They have completely replaced the front lower control arms and it still squeaks but only when it gets wet. Newly washed or when it rains.
It's ony when I go to stop. It's not that bad. Annoying, but I've learned to live with it. Tired of taking it back and forth to the dealer.
jjandascog
My 13 began to squeek at 7K, took it in and two new control arms later it is quite. Been quite for 2K so far....
Xorak
Memphis, TN
just FYI, the haven't redesigned the control arm bushings to cure the squeak so there's no guarantee that the replacements will be a cure. they're just playing the odds on most being quiet.
if i didn't live in an apartment complex with speedbumps i could have ignored it too.
GrabberBlue5.0
Gold Member
Louisville, KY
I've got almost 40k on my 11 with zero squeaking, I must be really lucky because with all of the small problems these are known to have I don't really have any
Xorak
Memphis, TN
i'll take control arm bushings over the trans grenading or #8 any day!!! LOL
fastregalwe2
Need more powa!
Virginia Beach, VA
mine squeaks too on the p/s, also has an exhaust leak and idles rough, 550 miles on the clock. Fixin to take it back as soon as I get a chance
tjm73
of Omicron Persei 8
Rush, NY
If you know it's the bushings and Ford can't/won't fix it, have some aftermarket urethane bushings installed. That will probably fix it. And it's an "upgrade".
Xorak
Memphis, TN
know where to find replacement bushings for the rear of the front lower control arm?
they come with new aftermarket lower control arms for either $500 or $800 depending on which of the two out there you go with.
tjm73
of Omicron Persei 8
Rush, NY
Prothane, Energy Suspension, Maximum Motorsports. It's really as simple as a Google search. Summit Racing has them in stock.
Xorak
Memphis, TN
apparently Google gives you different results. 05-10 and 11+ are different. Summit's $200 Prothanes are the 05-10 style. they don't show anything at all specifically for 11+.
remember, these are FRONT control arms, not REAR. :)
tjm73
of Omicron Persei 8
Rush, NY
Please elaborate in the differences. Is it a new part number? What changed? Is it dimensionally different or different in the materials used? Like say different durometer rating on the OE rubber? Has anyone laid them side by side and measured to see if they are dimensionally the same? If they are dimensionally the same, why has nobody tried using them?
I am amazed that nobody anymore seems to be able to look beyond a part number and a "fitment" guide to see if something might work.
Took about 3 minutes.....
http://www.steeda.com/store/prothane-mustang-front-rear-control-arm-bushing-kit.html
kona302
south texas
I noticed this also, but only sometimes it does it... Oh well Ill just swap stuff out later down the road.
Hcbr929rr2
I had a similar problem, dealer replaced my front sway bar end link bushings and haven't heard it since, they said where those mount were over torqued from the factory causing the squeak
sd_fox_racer
havent had a chance to go to the dealer but i might just do this in the driveway and see what happens
