ito717
Sitting at a stoplight and all of a sudden my stock 2014 GT Track Pack started bouncing around between 600 and 750 rpm at idle. I pulled up gauges and noted the air/fuel ratio moving, managed to catch a video at the next stoplight:
Hooked up a cheap code reader and noticed long fuel trims seemed high: LONGFT1: ~12.5 and LONGFT2: 7 Recorded a video of these too:
I have removed and cleaned the MAF and Throttle Body and removed the negative battery cable for ~10mins to reset the ECU and relearn idle. Problem still persists.
I'm thinking maybe a vacuum leak, but not really sure where to start?
Thanks in advance,
Ito
Thanks in advance,
Ito
