09bbbkgt
ok thanksBillet 67 will spool like 61's and flow like 76s up top.
i guess with those size turbos it would spool a lil bit faster. What about 76s
It would be a street tune and race tune setup. street tune wit 93 pump gas and race tune wit race gas. If it didnt make 1000 on street tune but did on race gas id be fine.
Had nothing to do with the sleeves, Bill. John told me personally that it wouldn't rpm worth a shit nor would it build middle rpm power. Even with four valve heads it had decent low speed response but not much power over a standard 5.4 engine. Higher up....same thing. Just didn't make a lot of power over the standard 5.4 setup.
Now....add boost, however, and it was a bad motherfucker.
WHat does twins and changing boost on the fly have to do with each other?So why would you not want twins where you could change boost on the fly. Heck you could even have a 0 boost valet setting if you want it.
For the street?.........no LOL!i guess with those size turbos it would spool a lil bit faster. What about 76s
You can't do that with a supercharger.
Don't say you can't, it's been done before.
To whatever boost level you want?
Billet 67's and be done with it.
Spin the blower close to max rpms and whatever boost the supercharger is capable of, then add the wastegate and boost controller. I'm not saying it's ideal but it can and has been done.
I thought I typed the part about the centri but reread and I left that part out. Like I said, it's not ideal, just letting you know it can be done. Turbo is the way to go, knowing what I know now, I wish I went that route instead of my paxton.
That works on a centrifugal. Not so much on a roots or twin screw.![]()
thanks man i would appreciate it.
Some of you people kill me.....
67's would be more ideal for street manners yes.... But if you think 76's want spool fast enough on a 5.4 based engine you are sadly mistaken....
You can't throw turbo's on an engine and say they don't spool fast so let's change them.... Many more variables in play.... Heads, cams, intake etc etc.....
A friend of mine is running a d-stroked 5.4, .020 over, ported Supercar heads, custom turbo cams with twin 76's.... Spool's better then you think.... 25lbs it made right at 1460.... And he plans to turn it up to 30-32.... Only pulled it to 7800 on that run and the motor was built to turn 9500 with ease.....
It can be done.... This car is street driven with a glide in it
Can you explain to me how you would have a "zero" boost valet mode? The least amount of boost you can run is what your wastegate is setup for. If you have a 10 PSI spring in it, that's as low as it can go. With a boost controller you can go higher, even on the fly, but not lower then what spring is in it.
Not just that but you'll be pumping an extra amount of hot air and possibly be running the SC on a part of the compressor map that's not ideal.
