Is the 3650 shaft the same as the 5r55s ? If so where do you want the mesurments from and to ? Also my shaft is for sale once again ,the other deal fell through, if you are interested and it will wok .
Ok here ya go . With the slip shaft fully compressed the DS measures 48 1/4 " from outside u joint flange to out side u joint flang. This is with a adapter plate being used at the diff. If you need other measurments I can get them in the morn before the shaft goes to the (pending) buyer.
