3M double-sided tapes
mulestang
All Show, No Go
Jacksonville, FL
Those of you with experience with 3M tapes - Which tape would be a better choice for attaching body parts (spoilers, side/hood scoops, louvers, etc): the VHB, or the automotive acrylic plus? Any specific recommendations? Thanks
hamish
B.C.
I'd go with the auto acrylic plus.
But there are some really great VHB products, just have to get the right ones.
TGR96
el blanco nino
Huntsville, AL
I really don't know which kind of 3M tape I have used, but whatever it was, it friggin' sticks!
05stroker
Never enough power guy!
Bullard Tx.
I use the 3M VHB at work. We assembly aluminum wall panels for commercial construction with it. It works well. You can clean the surface with denatured alcohol and it will stick very well. They also have a surface primer that you can use. With the primer, it wont come off. I have no experience with the other product though.
hamish
B.C.
Once again, you must get the right VHB as it is used on different substrates in industry.
Go with the wrong one and it will come off.
mulestang
All Show, No Go
Jacksonville, FL
Thanks for all the inputs! I'll contact 3m about the appropriate type of VHB to use.
Sent from my stinkin' iPhone using Tapatalk
o2sys
NY/NJ
That adhesion promoter works like magic. The difference in between using it during application is like night and day. Saleen uses it for their body kit install. Also they use window urethane glue for water tight seams.
Sent from my HTC One using Tapatalk
konablue11gt
Evansville IN
3M VHB red ..use with adhesion promoter...a lot of OEM stuff is shipped to the manufacters and installed on new cars using this. My company uses this stuff on quite a few applications we supply. Its actually required on some Ford specs
